Mar 14, 2019, 09:48 AM
XK K120 and Taranis QX7
Hi
I am using a Taranis QX7 with Jumper JP4in1 module to fly a XK K120. It is flying very smooth. I configure CH5 as gyro rate setting. When I am switching to 3D mode output of CH5 showing 1120 msec. But the heli won't be able to fly 3D rather it seems to level itself when I steers it for invert flight. Where am I missing? All suggestions are welcome.
Regards.
Mar 16, 2019, 04:32 AM
Ok, I figured out the solution. CH5 1900 msec is 3D mode not 1120 msec. The helicopter is flying nice.
Mar 19, 2019, 04:10 AM
mdxp67's Avatar
Hi 100 Ampere, glad u figured out the issue. I am trying to set up my QX7 too. Can u share your channel settings? Or better still your eepe file. I cant't seem to get my head around this opentx software.
Mar 26, 2019, 04:17 AM
Hi mdxp67,
My channel settings are as follows
channel order AETR (mode2)
Aileron and elevator 25% expo
all channels end point +/- 100% (you may need to reverse some channels please check your self, mine rudder and elevator reversed)
CH5 is configured with SWA, UP 6G (output 1120 msec) , Middle NONE, Down 3D (1900 msec)
in mixture page CH6 (Pitch) source is CH3 (Throttle)
I have no normal mode as the cyclic are not very responsive in low head speed. I use a flat 100% throttle curve.
in special function screen set SWF DOWN to override CH3 (Throttle to -103%) it will be throttle hold.
My pitch curve setting is -40 , -20, 0, 20, 40. You can try this or modify to match your flying style. I fly mild 3D.
New Product XK INNOVATIONS K120 REVIEW - 2s brushless cp micro heli rtf - courtesy of banggood microrcfiend Micro Helis 1963 Mar 16, 2020 10:52 PM
Discussion Fitting the metal head from the XK K120 to the XK K110 issues DavidDavidson Micro Helis 4 Dec 27, 2018 12:41 AM
New Product XK K120 Shuttle 6CH Brushless 3D6G System RC Helicopter Whitehouse Electric Heli Talk 7 Jul 11, 2016 02:42 PM
Discussion Xk k120 zzc Micro Helis 2 Jul 04, 2015 03:36 AM
