New Product
SKYSTARS Venom217 RC FPV Racing Drone PNP BNF W/ F4 8K OSD 40A Runcam Micro Sparrow 2
SKYSTARS Venom217 RC FPV Racing Drone PNP BNF W/ F4 8K OSD 40A Runcam Micro Sparrow 2 800mW VTX
Specification: Brand name: SKYSTARS Item name: Venom217 racing drone PNP/ BNF Receiver: without receiver/ IBUS(FLYSKY) receiver/ XM+(FRSKY) receiver (option) Recommend battery: 3-5S 1500-1800mAH Frame kit Wheelbase: 217mm Arm Plate Thickness: 6mm TOP&Bottom Plate Thickness: 2mm Side Plate Thickness: 2mm Material: 3k Carbon Fiber Weight: 79g Flight controller Micro F4 Flight Control Board ( D-Shot Version) MPU: ICM20608 CPU: STM32F405RGT6, dual 8K. Input Voltage: 2-6S Lipo Built-in Betaflight OSD to adjust PID BEC Output: 5V@3A Size: 30.5x30.5mm board, 3mm mounting holes (M3) Weight:7.3g Support Subs/PPM/DSMX receiver ESC 40A 2-5S Blheli_32 4 in 1 ESC: Input Voltage: 2-5S Lipo battery Constant Current: 40A Peak Current: 50A BEC Ouput: 5V@1.2A CPU: STM32F051 BLHELI_32 firmware Size: 36x36mm (main board) Installing Hole: 30.5x30.5mm, M3 Weight: 10g MOS Tube: TOP QUALITY MOSFET Support Damped Mode, Oneshot125, Oneshot42, Multishot, Dshot150/300/600/1200, forward and reverse VTX FPV Transmitter Output power: 25mW/200mW/500mW/800mW switchable Control mode:button OR Channel changes and Pitmode setting through PWM With a microphone, you can switch the audio flexibly BAT: 7-26V,BEC 5V-1A 310mA----800mW Video system: NTSC/PAL Antenna: MMCX Frequency: 5.8GHz 5 bands 40channels Weight: 4.2 g Dimension: 36*36*4.85mm Mounting Hole: 30.5mmx30.5mm Motor skystars 2306 KV 2600, race edition Camera Description: Image Sensor 1/3" COMS Sensor Horizontal Resolution 1200 TVL TV System NTSC/PAL changeable Image 16:9 WDR D-WDR Min, Illumination 0.005Lux@F1.2 Lens 2.3mm lens Synchronization Internal Electronics Shutter PAL:1/50~100,000; NTSC:1/60~100,000 S/N Ratio >52dB (AGC OFF) Video Output CVBS Audio YES Auto Gain Control YES BLC YES Camera OSD YES DNR 2 DNR Day/Night Auto/Color/B&W Dimension 19mm*19mm Wide Power Input DC 4.5-40V Work Temperature -20℃~+60℃ Work Humidity 20%~80% Weight 5.5g (N.W.) Propellers 5042 5inch 3-blade RGB LED With programming tail LED light Antenna Weight: 8g Size: 25mm x 25mm Gain: 1.6dbic Axial ratio: 1.0 (near perfect) Bandwidth: 5.5GHz-6.0GHz Radiation Efficiency: 95% VSWR: <=1.22 Connector: MMCX Works great as both a transmitting or receiving antenna Compatible with other styles of 5.8GHz RHCP antennas Package included: 1x Venom217 racing drone PNP/ BNF 1x battery strap 1x battery non-slip pad |
Thread Tools | |
Similar Threads | |||||
Discussion | Diatone GT-M515 FPV Racing RC Drone PNP Split Type F4 8K OSD Runcam Micro Sparrow 2 T | scousethief | Banggood.com | 22 | Jun 12, 2019 05:35 AM |
New Product | SKYSTARS 2019 Edge220 FPV Racing Drone F4 8K OSD 25-800mW VTX 40A Blheli_32 ESC Caddx | Merch | Banggood.com | 0 | Dec 05, 2018 06:42 AM |
New Product | SKYSTARS 2019 Edge220 FPV Racing Drone F4 8K OSD 25-800mW VTX 40A Blheli_32 ESC Caddx | Frimen | Mini Multirotor Drones | 0 | Dec 05, 2018 06:05 AM |
New Product | SKYSTARS Venom32 217mm FPV Racing RC Drone PNP F4 OSD 48CH 600MW 40A Blheli_32 Runcam | smg24 | Banggood.com | 0 | Oct 05, 2018 05:41 AM |
Discussion | Diatone GT-M515 FPV Racing RC Drone PNP Integrated Type F4 8K OSD Runcam Micro Sparro | scousethief | Banggood.com | 0 | Jun 27, 2018 07:46 AM |
