Mar 11, 2019, 09:10 PM
Making a Door into a Building Table?
I picked up a nice, straight hollow core door (80"x34") the other day for my next building table. I'm looking for some suggestions on how to frame it and add legs to turn it into a useful work surface. The only issue is I would like to not have it end up massively heavy duty and bombproof because I will need to break it down on occasion to allow the building room to become a guest room again. Because of this, I am wondering if leaving the door loose on top of a separate frame with the legs on it would be the best way to go?
Mark
Mar 11, 2019, 09:41 PM
The Junk Man
My main building board is a 24" hollow core door, set upon two trestles. It is clad in light sheet metal from Home Depot and I use magnets exclusively for on-the-board assembly. No more sticking pins into ceiling tiles, wood or cork.
Tom
Mar 11, 2019, 09:49 PM
Thanks for the pics. Since you posted it, are there more details on your honey pot glue holder?
Trestles = saw horses?
Mark
Mar 11, 2019, 10:07 PM
The Junk Man
Mark
Trestles are similar to saw horses and can be used as such. These were quickly made from 1x6 lumberyard stock.
Honey pot below.
Tom
Mar 11, 2019, 10:18 PM
Honey pot below.
Tom
Excellent, thanks. One last question - how high is your work surface and do you work standing or sitting?
Mark
Mar 11, 2019, 10:36 PM
The Junk Man
I work standing and prefer a rather high bench. I am in the house tonight and will measure when I go out to the shed tomorrow.
Tom
Mar 11, 2019, 11:14 PM
Play that funky music right
kenh3497's Avatar
One screw in each corner would be more than enough to secure the door to what ever frame you put under it.
If you use 2 X material for legs a hole can be drilled in the bottom of each leg and a lag screw put in to use as a leveling device. I would be concerned about a twist being induced into the door. Part of the reason for the lag screws so that could be adjusted out. An easy way to check for a twist is to use two strings, one at the front and one at the back. Place the strings on small blocks so they are suspended from right to left above the table surface. Now step back "some" and sight across the strings. If you only see one string you are good to go. If one corner is high or low the strings will separate and tell you which corner to adjust.
Ken
Mar 12, 2019, 08:42 AM
Summit Model Aeronautics
Steve85's Avatar
I don't remember where I got them, but my building surface is held up with a pair of the metal legs used for folding tables. If I need to put the bench away, it's easy to fold the legs up.
Just Googled around a bit and Wal-Mart has these legs for $25 a pair.
Steve
Mar 12, 2019, 09:07 AM
The Junk Man
Mark
I measured this morning... the building surface is 38 inches high.
And there is no need to attach the door to the trestles at all, it just sits there. Easily moved aside if needed.
Tom
Mar 12, 2019, 09:17 AM
Hard to beat the "Wal-Mart" legs mentioned above..... they tuck up against the bottom of the "table/door" when you need the space
Michael in Ontario, Canada
Mar 12, 2019, 10:03 AM
Scott
Pylonracr's Avatar
Doors make great building tables. The only problem I can foresee is dramatic changes in humidity might cause the door to warp.
Scott
Mar 12, 2019, 10:21 AM
The Junk Man
Scott
Nope. Hollow core doors are torsion boxes. Do a Google search. They are about immune to warping.
Tom
Mar 12, 2019, 10:51 AM
That's one of my concerns as well and part of why I think floating the door on a frame or stands is a good way to go.
Are they high enough to work while standing? I used to use an old drafting table for my work surface but got rid of it years ago when space was an issue and I wasn't actively building and flying. Now that I'm getting space and time again I am rebuilding my modelling kit to suit what I have space for.
Thanks, Tom. I am thinking loose on top of legs or a frame is looking good for me as well if I don't find a set of folding legs that work height-wise. Even a set of these saw horses would work with a 2x6 added to the top for extra height:
https://www.homedepot.ca/product/hus...ck-/1001012218
As Tom says, they are built as a torsion box so they don't warp easily. Also, I live in central Alberta and our humidity is low and pretty steady so it isn't much of an issue for me compared to people in coastal areas and the like.
Mark
Mar 12, 2019, 12:18 PM
The Junk Man
For the price of those Home Depot saw horses, you could build a dozen of my trestles, customized for the right height from the get go. And get'em done in a short afternoon.
Tom
Mar 12, 2019, 12:51 PM
Tom
You haven't seen the wood prices up here!
But your point stands, they would be cheaper and I can get exactly what I want out of them without tweaking.
Mark
Discussion Kid makes Lego door operator dll932 Life, The Universe, and Politics 12 Oct 14, 2015 03:27 PM
Mini-HowTo Dr Frankinstien uses Tesla waves to make a cabbage grow into a monster treehog Life, The Universe, and Politics 6 Sep 23, 2015 04:08 PM
Making a building table? mudfarmer_mike Beginner Training Area (Aircraft-Electric) 12 Mar 23, 2002 07:03 AM
