Mar 15, 2019, 07:34 PM
Fibertech n More
DuaneV's Avatar
Originally Posted by GoatZilla
Congrats to ISDT for not settling on a consistent connector layout.
What do you mean? These are XT60 and they work with EC3s as well.
Mar 15, 2019, 08:17 PM
artopsy's Avatar
and deans connectors too.
someone needs to make converter plugs for the smart ec3 batteries to the original xt60 smart batteries and vice versa
Mar 25, 2019, 08:57 AM
Eagles View Aerial
b0gh0s's Avatar
Anyone else having a problem with their air charging batts out of balance? Mine won't seem to finish a charge cycle and the cells are all over the place when it's done. My Q6 seems to charge the same batteries just fine.
Mar 25, 2019, 09:59 AM
artopsy's Avatar
Now that you mention it
it does seem to struggle with out of balance batteries especially HVLi ones. takes quite a while to balance these but gets very close when its done.
May 15, 2019, 09:38 PM
after updating firmware to 1.0.0.32 my H605 air chargers are both reading wild individual cell voltages-- for a pack that is 4.2 on each cell per the multimeter the chargers are saying 4.3, 4.4, 4.3, 4.7 and 4.2, 4.2, 4.2, 3.73.
I see in the settings there is a box for manual voltage configuration but when I try to change those values it says "parameter setting failed"
May 15, 2019, 09:41 PM
artopsy's Avatar
i have also noticed if i charge a battery on the 605 air. it charges the pack above 4.2 per cell. this makes discharging or storage charging un used batteries not possible on other chargers like the Q6
May 15, 2019, 11:30 PM
Originally Posted by ltc
I must have missed something.
What’s wrong with the connectors?
The XT should be on the other side of the balance connector
May 16, 2019, 12:54 AM
After tinkering for a bit, it appears the newest firmware version for these is a little rocky. Before updating it was reading balance voltages relatively well, after updating it is all over the map and wildly different on my two chargers. Complicating matters further, the iOS app cannot properly update the calibration settings, however the Android app appears to work without much issue. After calibrating it to 4.2 per cell based off a known good battery it appears to function properly and balance cells close enough that other chargers won't reject them.
Please please keep the firmware updates coming-- they are badly needed and the form factor / size / price / one touch are all perfect for field charging.
New Product iSDT SC-608 150W 8A & SC-620 500W 20A & Q6 Plus 300W 14A Balance Chargers czajunia Batteries and Chargers 1734 Apr 24, 2019 10:39 PM
New Product iSDT SC-620 500W 20A MINI Smart LCD Battery Balance Charger SeByDocKy Batteries and Chargers 0 Jun 12, 2016 06:27 AM
Help! Batter Charger- R-605 with no power supply? yeggles Batteries and Chargers 1 Apr 08, 2012 11:22 AM
Discussion Anyone using an Air Hogs Reflex charger with a Syma S107? Jids Electric Heli Talk 0 Feb 28, 2011 08:18 AM
Help! Trouble with recording with an Archos 605 StealthWorkx FPV Talk 13 Jan 22, 2011 07:34 PM
