This thread is privately moderated by Blaze0021, who may elect to delete unwanted replies.
Mar 10, 2019, 08:11 PM
Blaze0021's Avatar
Video
Eflite F-15 Eagle 64mm EDF BNF Basic Flight
In 1080p 60fps - The Eflite F-15 Eagle 64mm EDF BNF Basic in the Splinter Camo is a perfect "twin" to my already excellent FMS F-15 Eagle V2 64mm EDF in Sky Camo.
Eflite F-15 Eagle 64mm EDF BNF Basic Flight (4 min 25 sec)
My Eflite F-15 Eagle 64mm EDF is completely stock. Powered by a Pulse 4S 2250mAh 45C lipo, weighing in at 240 grams. CG was set rearmost to 85mm from the leading edge of the main wing at the fuselage. Flight Timer was set to 3:40 minutes. Flown with a Spektrum DX8 G2 Transmitter at 100% rates, with 24% expo to the Ailerons and 5% expo to both the Elevator and Nose Wheel.
Flight video footage taken with Mike's iPhone X on 1080p 60fps.
Thanks for the video capture Mike!
And as always, thanks for watching!
***CG TUNING UPDATE: After several more tuning flights, I found my CG of choice to be further back at 91mm from the leading edge (that's basically pushing my 240-gram Pulse 4S 2250mAh 45C lipo as far back in the cavity where the front edge of the battery is lined up to the back roof edge opening of the canopy hatch. Doing this allows the Eagle to float in with minimal throttle management on final approaches, with no negative issues in flight. This was actually the CG I used in this flight video, not the previously stated 85mm.***
New Product E-flite F-15 Eagle 64mm EDF BNF Basic/PNP Jason M Foamy EDFs 345 Dec 10, 2019 09:55 PM
News F-15 Eagle 64mm EDF BNF with AS3X and SAFE Select (EFL9750) Jim T. Graham Foamy EDFs 374 Dec 10, 2019 09:54 PM
New Product ETM - F-15 Arctic Eagle - Twin Edf 64mm SkylineFlyer Foamy EDFs 17 Feb 20, 2010 12:02 AM
