Mar 08, 2019, 07:00 PM
Need help finding a motor and esc for a Herr J-3
Hi everyone,
I have a Herr J-3 Cub with a 35 1/2" wingspan. Sig recommends a 30-40 watt; 1200-1700kv; 16-25 gram weight motor. So want motor and esc would you guys recommend?
Mar 08, 2019, 08:05 PM
IMO ( In My Opinion ) →
balsa or carbon's Avatar
Heads Up RC has fast $3 flat rate shipping , and I would recommend these electronics :
https://www.headsuphobby.com/HURC-25...or_p_1961.html
https://www.headsuphobby.com/Sky-Pow...EC_p_1022.html
HURC also has servos , propellers , batteries , etc .
Mar 08, 2019, 11:02 PM
Looking for something with more power.
Mar 09, 2019, 12:07 AM
80 watt : https://www.headsuphobby.com/Power-U...or_p_2294.html
Mar 09, 2019, 12:35 AM
pull up -- PULL UP!!!
I use these 20g motors with 300 to 450mah 2S batteries on several small planes. They make over 400g thrust with an 8043 prop, enough to give my 32"-class 3D planes unlimited vertical. ESCs are 12A Hobbywing Skywalkers.
https://www.buddyrc.com/sunnysky-x2204-1800kv.html
Mar 10, 2019, 09:51 AM
How many watts do they draw? I'm looking for a motor that uses 40 watts. Weighs 20 grams and 1700kv and turn a 7" - 8" prop. And a esc to go with it. I'm very new to the brush less motors. I came from the a long time ago and brushed motors.
Mar 10, 2019, 09:58 AM
My thrust stand test results on 2S battery:
8040 GWS prop, 294g thrust, 8.0A, 63W
8043 GWS prop, 434g thrust, 9.7A, 76W
Mar 10, 2019, 11:20 AM
What you using for a esc? What is the make of your airplane and the weight of the whole thing?
Mar 10, 2019, 02:46 PM
As I said, 12A Skywalkers.
Several 3D planes, all in the 200 to 220g AUW range.
Discussion Motor help as need a new one and can't find what I need Treeguy1984 Power Systems 7 Apr 30, 2017 05:18 PM
Discussion Need help finding 10s esc eightbitbeast Car Talk 1 Jun 01, 2016 08:29 PM
Question Need help finding a motor for my build, cannot find motors that will work. allofyourmoney Multirotor Drone Power Systems 11 Oct 10, 2015 09:52 AM
Discussion Need help finding a new motor for my Losi MSC-MXPro ESC! larsen2000 Electric Power Cars 6 Aug 20, 2013 02:55 PM
Discussion Herr Piper J-3 Cub, what would be the best battery/ESC for geared speed 400 motor? Mittens16 Parkflyers 9 Dec 31, 2009 06:03 PM
