Mar 01, 2019, 08:52 PM
Antdude
Help!
Problems with erratic throttle
[COLOR=[COLOR=""][/COLOR][/COLOR]Hello I am new to the hobby and have a couple of ? 1?does any one know what would make a drones throttle to be erratic meaning after it s powered up without props on and after I raise throttle and bring it back down again that the throttle will operate by its self with out my hands even on transmitter. Meaning throttle goes up down up down then middle then I disarm it and when I re arm it. It will idle fine until I throttle up and try to bring it down it goes crazy like before 2?where do I go to download beta flight with no problems thank you all antdude
Mar 02, 2019, 06:16 AM
It's normal. The gyro is picking up vibrations from the motors and it is trying to correct itself like if it was in the air. It won't behave that way when airbourne. If you havn't done it you should calibrate the sticks to 1000-2000 and mid to 1500 in Betaflight and the radio. Also before the first flight, be sure to set up and check your failsafe is working without props on. That way if it does anything crazy you can just shut the motors off.
Get the Betalight Configurator Standalone here
https://github.com/betaflight/betafl...rator/releases
Mar 02, 2019, 06:53 AM
Antdude
thank you airvortex I will try when rain stops
Mar 02, 2019, 06:56 AM
Antdude
forgot to mention that when I use the throttle o r try to use it won't let throttle down I habe to disarm it
Mar 02, 2019, 07:18 AM
Again it sounds quite normal what you describe. Another thing you should do before flying. Check the throttle, aileron, elevon, yaw are mapped onto the correct sticks. Look at the receiver tab in Betaflight to verify.
Mar 02, 2019, 07:42 AM
Antdude
Ok will give it a shot and yes the sticks are set up the way they should thank a million
Mar 02, 2019, 11:19 PM
Antdude
Throttle
Hey vortex well I did what you suggested and it does the same thing. I have no control once I'm airborn
Mar 03, 2019, 04:11 AM
Give a full list of your kit and radio. Did you buy it all new or used ?
Mar 04, 2019, 06:42 PM
Antdude
Uaed
Mar 04, 2019, 06:45 PM
Antdude
F3 flight tower 2207 motors dal props and a taranis plus trans
Mar 04, 2019, 11:08 PM
I would try this
Create a new model in the radio and rebind then do a test flight
If it still makes no difference.
Then try re-flashing the firwware on the fc to a different version.
Mar 05, 2019, 01:34 AM
Antdude
Ok will try thanks for all your help sofar
Mar 10, 2019, 12:27 AM
Antdude
Throttle warning
[B/can anyone tell me how to get rid of throttle warning[/B]
Help! Erratic startup problem with one specific motor of a Quad George Gassaway Multirotor Drone Power Systems 1 Apr 03, 2017 01:48 PM
Discussion First build. Erratic Throttle? Bonacci01 Beginner Multirotor Drones 1 Apr 03, 2017 07:17 AM
Help! Erratic Throttle on HT F801C mld03c Beginner Multirotor Drones 1 Dec 08, 2015 06:24 AM
Discussion PROBLEMS with X4 Drone, Erratic fly switching batteries jagg97 Mini Multirotor Drones 5 Nov 09, 2015 08:07 PM
Help! Little problem with the Night VisionAir with no throttle or controls working? pricelessppp Electric Plane Talk 4 Sep 17, 2015 05:54 PM
