This thread is privately moderated by Bchirrick, who may elect to delete unwanted replies.
May 04, 2019, 11:33 AM
pnc
pnc
pnc's Avatar
What is the max weight it can handle ?
May 04, 2019, 11:50 AM
This one, 140oz, i would keep it around 100. There are larger cells available if needed
Latest blog entry: DLG Pegs
May 21, 2019, 11:04 AM
Sherpa
Schwemmer's Avatar
What is the widest fuse it will accommodate? I fly PSS type slope gliders and the widest I have is 5 3/4 inches or 145 mm wide.
Thank you Rick
May 21, 2019, 11:13 AM
What is the max weight, max chord, max width of the fuses?
May 21, 2019, 07:30 PM
So i knew it would take a while but for giggles i stretched this one. Takes a while to print. Had it going for 6hrs!. About 150mm width, but about 60mm deep. How deep do you need?. Not really familiar with slope plane sizes.
May 22, 2019, 05:25 PM
Sherpa
Schwemmer's Avatar
That would be more than enough to suit my needs.
Thank you
Jun 02, 2019, 02:01 PM
Had a chance to fit it together. 150mm width between pads, 150mm from front post to back pad, 60mm depth. Ended up having to widen the base. But, i had run out of orange, so the base ended up green. Installed two 5kg load cells, so it should handle over 15 lbs.
Is that depth enough?
Jun 24, 2019, 12:57 PM
Found all the source and thing files, but is there an electronics description somewhere?
Jun 24, 2019, 05:18 PM
Post #1 link references the original project. You will find it all there. This project was was a derivative of the original project.
Aug 19, 2019, 07:43 PM
Big scale
150mm width
150mm from front post to rear pad
65mm depth, top of pads to cradle
Sep 10, 2019, 02:42 PM
Cloudracer's Avatar
Im interested in this scale but wold like to know about warranty and service if there are problems in the future?
Sep 10, 2019, 03:18 PM
They are all calibrated and tested before sending them out. Never had a problem with any of these. If you have a problem, let me know. There is no reason it won’t last for many many years. The only reason it would fail would be overloading it, which would be hard, or water damage.
Sep 10, 2019, 04:19 PM
Cloudracer's Avatar
Does this unit have to be Wifi connected? or can it be plugged directly into an iPhone or Android?
Sep 10, 2019, 04:45 PM
No. It creates an access point, it’s own WiFi. You supply power via micro usb and connect to it via your smart phone, tablet, computer, etc. There are no wires going from your phone to the scale. The connection is done wireless.
If you watch the video, turn the unit on by supplying power, go to your WiFi settings on phone, computer, etc, and select it. Then open your browser via chrome, explorer, safari. Just like a www. Address , you type
192.168.4.1 in the adress bar. This brings up the cgscale page.
Check out the video below. This phone Is Just connecting wirelessly to the scale.
CG Scale (1 min 18 sec)
Discussion CG Scale geek way natxopedreira Electric Competition Soaring-F5J/ALES/e-Soaring 732 Oct 12, 2019 04:29 PM
Discussion CG digital scale mrfski Multi Task F3X 3 Jul 12, 2018 06:09 AM
Discussion CG Scale for F3K jrs_123 Hand Launch 1 Feb 05, 2018 06:03 PM
Discussion 3D printed CG locator, fixed, single digital scale kcaldwel Electric Competition Soaring-F5J/ALES/e-Soaring 41 Jul 30, 2017 03:18 PM
Discussion 1/4 SCALE Edge 540 phoenix Models 68" - setting CG lyvewire Giant Scale Airplanes 0 Aug 29, 2016 02:39 PM
