This thread is privately moderated by TinkleWid, who may elect to delete unwanted replies.
Feb 28, 2019, 03:14 PM
TinkleWid's Avatar
Gallery
Classic Caddx Turtle V2 🐢 Cinematic Style - Ride of the Valkyries
🔊🔊🔊 Full Volume Recommended 🔊🔊🔊
Upscaled to 2.7K @ 60FPS for best picture
Classic Caddx Turtle V2 🐢 Cinematic Style - Ride of the Valkyries (4 min 10 sec)
I never imagined that classical music would suit my flying style but it's perfect for those cinematic drone shots !! Atypical weather for England in February; last year it was snowing at this time !
Music- Wagner incl. Ride of the Valkyries
Equipment Used:
Flying the Kwad Karl (Bando Racer 3) BR3 Frame with Caddx Turtle v2 https://www.armattanproductions.com/...duct_grid/2209
XJB 145 build and motors https://www.banggood.com/HGLRC-Flame...18277502201801 [hglrc xjb 145]
Caddx Turtle v2 https://www.banggood.com/Caddx-Turtl...18277502201801
XM+ https://www.banggood.com/Frsky-XM-Micro-D16-SBUS-Full-
Range-Receiver-Up-to-16CH-p-1110020.html?p=YE151218277502201801
VRD2 Pro Goggle rather than the TopSKy Prime 1S https://www.banggood.com/Eachine-VR-...tlinkid=124518
Jumper T8SG https://www.banggood.com/Jumper-T8SG...d=124521124520
Gemfan 3052 https://www.banggood.com/2-Pairs-Gem...18277502201801
Adobe Premier Pro for Caddx V2 post-production
I still think this footage is better than the output of the Runcam Split Mini 2 . It's not quite as good as as a Go Pro but at least as good as the Foxeer Mix; what fpv hd camara do you think is best?
Firmware version dated 7th September 2018
Caddx Turtle Settings: 1080p 60FPS
Wide FoV
7 saturation
1 Sharpness
5 Contrast
5 Brightness
EV -0.3
WDR on
Ensure you lower the sharpness to 0 or 1 unless using another lens
Caddx Turtle V2 is NOT ALWAYS SHIPPED WITH THE LATEST FIRMWARE 😱😱 The latest caddx turtle v2 firmware is AMAZING 😱😱
(Note: How to repair a bricked Caddx Turtle with black screen)
How to repair a bricked Caddx Turtle from a firmware update
http://www.multirotorguide.com/guide...rmware-update/
September Firmware - works with v2 and soon to be tested with v1 board https://www.rcgroups.com/forums/show...5&d=1541439082
How to update Caddx Turtle firmware (step-by-step):
UPDATING CADDX TURTLET (5 min 44 sec)
The latest firmware now is January 2019. Image quality and settings are unchanged and Caddx have adopted their UART protocol to one of the protocol versions that Runcam has. If so - you should connect the RX and TX pads on your Turtle V2 to unused UART Tx and RX pads on your FC. Then configure accordingly in the Ports tab in BF. However some users have reported bug so if you do not need to control when the camera record I would advise avoiding this release of the firmware. Stick to the September 7th release for now.
The main issues are related to how the Turtle is installed:
- Good clean power supply and avoidance of ground loops
- Some air needs to pass the board to avoid over heating.
Caddx Turtle/RunCam Device Protocol
https://github.com/betaflight/betafl...evice-Protocol
CADDX TURTLE/TURTLET SOFTWARE UPDATE V2.1
https://lunchboxfpv.zendesk.com/hc/e...RE-UPDATE-V2-1
What changed?
-Fixed power button issue to turn on and off DVR
-Increased Bitrate
-Brightness and Sharpness adjustment
Caddx Turtle Competitors -
Foxeer Mix HD Camera (vs Caddx Turtle v2)
http://foxeer.com/Foxeer-Mix-1080p-6...V-Camera-g-213
Foxeer Mix HD Camera UK
https://www.unmannedtechshop.co.uk/p...hd-fpv-camera/
Review Foxeer Mix vs Predator V3 (Discounted)
https://www.banggood.com/Foxeer-Pred...tlinkid=127401
Caddx Tarsier 4K HD Micro Camera
Rumours Caddx Tarsier will have 4k resolution and 10ms lag !! Can this be true?
Mar 19, 2019, 11:01 AM
Latest Caddx Turtle firmware appeared in the wild, dated 2019 Jan 17. Link here: https://www.rcgroups.com/forums/show...&postcount=661
Mar 19, 2019, 01:09 PM
TinkleWid's Avatar
Thank you - I hear that the 2019 Jan 17 firmware fixes the horizontal lines issue in the HD recordings
Discussion Caddx Turtle V2? monas FPV Equipment 2 Sep 28, 2018 03:43 AM
