FOXTECH T3500 Tethered Power System for Drones
Tethered Power System is designed to provide unlimited, reliable and redundant power source for UAV, which helps UAV overcome the limitation of flight duration and payload capacity, can fly as long as required without worrying about landing to change batteries.
This just in from Foxtech...
Tethered Power supply ground station provides power through the ultralight-tether to the drone for unlimited flight time. The onboard power replaces the battery, enables you to fly as long as required without worrying about landing to change batteries. Tethered Power System ensures not only the long flight duration, also ensure the high reliability and ability to carry heavier payloads like stabilized HD zoom cameras etc.
The tethered power supply system converts the 220VAC power into the DC power required by the onboard power system. And the onboard power system only 700g, max output power 3500W.
This tethered power system coupled with commercial drones can be applied in many different fields by loading different equipment, mainly used as mobile relay station, and to provide secure and reliable high altitude long time aerial monitoring and for emergency lighting. The live aerial monitoring data can be wirelessly shared through the relay station to whatever broadcast system or monitors.
Owe to the unlimited flight duration, tethered drone is suited for many industrial applications where manned aircraft and even free-flying drones are unable to deliver. Tethered drones will become a vital commercial, engineering and lifesaving tools. Tethered Power System is suitable for various drones like GAIA 100,gaia 120, gaia 160MP hexocopters,F1000 Pro quadcopter and also suitable for DJI Inspire 2, Matrice 200 and DJI S900 etc.
Specs
  • Base Station Weight: 30kg
  • Cable Weight: 1.6kg
  • Cable Length: 100m
  • Output Voltage: 6S/12S
  • Output Power: 3500W
  • Voltage Input: 220Vac 50Hz
  • Tensile Strength: 50kg
  • Suggested climbing/landing Speed: 1.5m/S
  • Size: 66x63x40cm
Learn More
Go to Foxtech for more info!
Discussion DJI M200 Ground and air tethered power system hdworld Multirotor Drone Talk 1 Jun 18, 2018 06:53 PM
Discussion Tethered Drone Fami07 Power Systems 7 May 27, 2016 05:21 PM
Alert Help for fast deflation system for tethered captive balloon phoebeke2 Blimps 2 Sep 20, 2005 02:13 AM
