This thread is privately moderated by scousethief, who may elect to delete unwanted replies.
Feb 28, 2019, 07:26 AM
Quad Erat Demonstrandum
scousethief's Avatar
Mini-Review
Eachine TD600 25/200/600/800mW 5.8GHz 40CH FPV Transmitter DVR VTX Upgraded Long Rang
https://www.banggood.com/custlink/KDKvYejrSM
The Eachine TD600 is a stackable Video Transmitter that combines an "inline DVR" ( it records on the vehicle ) and a 40Ch video transmitter with SmartAudio !!. The board is a standard 36x36mm board and can easily be stacked along with your FC, ESC's etc. The TD600 is EXTREMELY well made as the photos will show and with all necessary wiring already attached and protected by silicone the only thing you need to do is solder it to your existing equipment. I had mine connected in less than 10 seconds it really is that simple. The icing on the cake is of course the MMcX connector, more and more antennas are produced using this little "Click in" connector , i have been using mine since last year on another model that has had multiple antennas used during testing and the connector is as solid as the day i bought it.
Description:
Brand Name: Eachine
Item Name: TD600 VTX
Input Voltage: 7-26V DC
Power Supply: 5V output for camera
Output Power: 25mw/200mw/600mw/800mw Switchable
Antenna Connector: MMCX
Version: SMA Female, RP-SMA Female(optional)
Cable Connector: Solder Pads
Dimension: 36*36mm, 30.5 stackable hole
Weight: 10.21g (excluding antenna)
Support TF Card: Max 32G
Extra Features: DVR, Smart Audio
This is For Your Reference Only:
5V Camera supply: 154mA (Typical value)[email protected]
5V Camera supply: 230mA (Typical value)[email protected]
5V Camera supply: 340mA (Typical value)[email protected]
5V Camera supply: 440mA (Typical value)[email protected]
Features:
7V-26V wide voltage input.
Support Pit mode and DVR function.
Support smart audio, use OSD configaration via smart audio.
25mW/200mW/600mW/800mW 4 levels power switchable.
Button control channel select mode, select channel,band and power via button.
Support LED Display, can display channel,band,power successively after setting.
English Manual, Click Here
Package Included:
1 x Eachine TD600 25/200/600/800mW 5.8GHz 40 Channel FPV Transmitter
1 x MMCX Linear Antenna
1 x Pigtail cable
1 x Manual
New Product Eachine TD600 25/200/600/800mW 5.8GHz 40CH FPV Transmitter - Free Testing BGKevin FPV Equipment 31 Apr 26, 2019 06:14 AM
Discussion Eachine TD600 25/200/600/800mW 5.8GHz 40CH FPV Transmitter DVR VTX Upgraded alex_nikiforov Banggood.com 3 Apr 26, 2019 06:05 AM
New Product Eachine TX805 5.8G 40CH 25/200/600/800mW FPV Transmitter -- Free Reviewing BGKevin FPV Equipment 61 Apr 14, 2019 02:22 AM
Mini-Review Eachine TX805 5.8G 40CH 25/200/600/800mW FPV Transmitter TX LED Display Support OSD/P siriusflier FPV Equipment 8 Mar 07, 2019 09:43 AM
