Dec 11, 2019, 02:52 PM
OpenTX core team
3djc's Avatar
Originally Posted by DarkSoulRL
On RC1, changing the background color in the standard theme does not work.
I have opened an issue on our tracker, so you can check when it gets solved : https://github.com/opentx/opentx/issues/7185
Dec 11, 2019, 02:54 PM
OpenTX core team
3djc's Avatar
Originally Posted by Hubert1
I have some issues not with the jumper transmitter but with the JP4IN1 module in a horus. I figured this would be the best place to ask. First off, the module is a fairly loose fit, is this normal? If I shake the radio I can hear it moving around. NOt a huge amount, but I feel like it should be a tighter fit. Bigger issue though is in the module status in external rf. Normally, I believe it is supposed to show the version of the firmware of the module. It does that sometimes, but the version changes from v1.2.something all the way to v77. something! I doubt a v77 even exists... Other times it shows protocol invalid, or no MILTI_TELEMETRY detected. It does usually bind, but gives telemetry lost and rf critical warning all the time. The place I got it from offered an exchange, but I want to make sure this is not normal and not easy to fix,
Hubert.
Looks like you have poor contact, try bending just a little the bottom pin
Dec 11, 2019, 03:00 PM
Ben Lye
Originally Posted by nira
Hello,
I have shared before here in the forum my issue with the internal multi-protocol module. So far, I have purchased 2 internal modules from different stores.
The first one was from Aliexpress-Jumper store ,after module was installed and radio was upgraded to the latest open nightly TX firmware ,in model menu when internal module is activated- I was getting module status" No MULTI_TELEMETRY detected". The module was also upgraded via Multi flash tool to the latest firmware and after some testing,I discovered that module is binding to receiver and I am able to control a servo,connected to the receiver /regardless the status of the module/. No RSSI signal bar is shown on the radio.After reading some of your comments here,it was suggested that problem is in the internal module and it is hardware related. Aliexpress /Jumper / refused to recognize the hardware issue and stopped replying to my e-mails. I purchase another module from different store,the module arrived and was installed in the radio - I get the same error message in module status in model menu,internal RF checked - " No MULTI_TELEMETRY detected"
*** all cables /connection were inspected
*** internal module is flashed with noinv firmware
*** external multi module works just fine,telemetry is showing O.K
At this point my conclusion is ,that something is wrong with the radio main board. But,if the external module is using same connectors,board - why is working fine???
I appreciate your help and comments !
Nick
If you've replaced the module that really only leaves the main board and the ribbon cable which connects the internal module to it. The internal and external modules use different pins for telemetry, so it's possible that there is some bad soldering or a bad connection on that pin somewhere on the PCB, which wouldn't affect anything else.
Dec 11, 2019, 08:53 PM
Sound File names
What is the maximum length for the name of a .WAV file in OpenTx?
I had read somewhere that it initially was 6 characters but that there may have been a change later on in its development.
Dec 11, 2019, 09:53 PM
Jumper makes laptops too?
https://m.aliexpress.com/item/400025...A1575297179673
Almost ordered one
Dec 11, 2019, 10:00 PM
Does it have Hall sensors in the mouse pad?
Dec 11, 2019, 10:05 PM
casual park flyer
52Sabre's Avatar
Almost ordered one
And . . https://jumper-healthy.aliexpress.co...67b72bb7gV2JAE
Dec 11, 2019, 10:10 PM
Almost ordered one
What's it a clone of?
Dec 11, 2019, 10:54 PM
mshagg2's Avatar
It's running a fork of Windows, heard Microsoft might add official support!
Dec 11, 2019, 11:25 PM
Originally Posted by 52Sabre
I have one of these by the way......and it's surprising good
Dec 12, 2019, 12:22 AM
Originally Posted by jonE5
Check out this battery option.
http://www.rcbatterykit.com/index.htm
Dec 12, 2019, 01:13 AM
OpenTX core team
3djc's Avatar
Was initialy longer, but now 6 characters (changed when horus arrived)
Dec 12, 2019, 01:43 AM
Edit frequently by bad English
ken2011's Avatar
It's not available in Japan...
Dec 12, 2019, 03:09 AM
I am Jumper biggest fan
Dec 12, 2019, 06:41 AM
Beach Bum
Steve FliesLow's Avatar
It costs too much anyway. price should be less than $20 U.S. Try this one;
https://hobbycool.com/products/7-4v-...28407800234084
Discussion Jumper T12 Open Source 16ch Radio with JP4-in-1 Multi-protocol RF Module Hobby Porter Radios 744 Jan 17, 2020 10:44 AM
