Hey Pascal,
Just wondering, any danger of a DSM/X trainer emulated receiver mode on the MPM like the frsky / flysky ones, much as I dislike Spektrum it's awfully popular |
I just received my new Jumper with OpenTX 2.3.2 and V1.3.0.44 on the module. This afternoon I bound it to an E-flite UMX Timber. I am only able to get approximately 100 feet of range while doing a check and also flying before I start getting range warnings. Any ideas?
Thank you mshagg2, that's good to know. So, if I put the Jumper in "Range" test mode and check the control surfaces from that same distance and they are functioning properly, I should be good, right?
You can also reduce the RSSI alarm values to their minimum to reduce the chatter coming from the radio. You'll probably still get 'telemetry lost' 'telemetry recovered' warnings. |
A drone setup is really no different than a fixed wing setup. It's just a matter of matching your channel order between the Tx and your choosen FC/firmware.
OpenTX upgrade on JT16 Pro
If anyone can help me understand this...
I have a Jumper T16 Pro with internal module, but shipped with the Jumper version of OpenTX. Does that me I have to update the bootloader on the the module? And having done that, I'm stuck with a nightlies version of OTX? Surely there is a stable version for the T16???? Many thanks R |
Thread Tools | |
Similar Threads | |||||
Discussion | Jumper T12 Open Source 16ch Radio with JP4-in-1 Multi-protocol RF Module | Hobby Porter | Radios | 735 | Nov 07, 2019 03:58 PM |
