Also unrelated, what do the aircraft symbols next to the model in the selection page represent, I've always wondered... |
They are meant to represent model usage so that your avorite/most used models can be easily found, but we havent made the code behind that yet
To get them to display as I have it on the T16 you long hold TELE button and page until you see an option to Setup the top bar then scroll to it and click it. Once there scroll to select "value" and then scroll to select GV1 as the source. |
Jumper T16 2.4G 16CH OpenTX Multi-protocol Radio
I recently came across the spectrum analyzer feature in the t16 tx tools menu after upgrading to the latest nightly otx and multi fw versions.Has there been any details on usage? Yes I see the band displayed and one spike I’m sure is something in the band, but not much else until I go to my local field.
Thanks Sent from my iPhone using Tapatalk Pro |
Similar to the motor time timer I use. Armed + -98 or greater counts up, anything else does not. |
Didn't look in FM I was looking for it's own tab Thanks to all |
if we could combine that with this it'd be perfect! https://rc-soar.com/opentx/lua/showitall/index.htm |
Reason: I'm an idiot
Hello again
and first of all thank you for your patience. What can be wrong in this sequence: Got a LBT EU X8R receiver. Connected to external module with the wright cabel (you know + and - changed) and update firmware as external module to NONEU. !strange after writing I had no confirmation of dowload successfull Tried to bind with my external module XJT in D16 or D8 with no success .... mince Any Idea ? |
You haveto chose on Tx module setting FRSKY LBT Ch1 CH16 |
Sd card or hardware issue
This my second post about this issue, sorry about this
when I start my jumper everything load normally voices, widget,model all menu working but when I do "Model Select" I get a generic page with no model name and I Just tried a brand new Sandisk SD (third card) same difference .and before this I checked if the ribbon cable was properly fitted So is it hardware or some issue in the firmware? I am aware the card reader can also be the culprit but I don't understand in this case why all the other function are working although I know they may be load in memory before) Edit Well I suspect this because of a Widget or lua script because i f I change this particular model for a blank one, and turn the TX off and on the models load with name and I can reproduce the issue by selecting the other model again So I am going to remove all widget on that particular model and brig them back one at the time to find the bad one Kind of strange but LUA can mess things around, although in openTX simulator I cannot reproduce this behavior. |
Thread Tools | |
Similar Threads | |||||
Discussion | Jumper T12 Open Source 16ch Radio with JP4-in-1 Multi-protocol RF Module | Hobby Porter | Radios | 735 | Nov 07, 2019 03:58 PM |
