Nov 29, 2019, 08:14 PM
mshagg2's Avatar
This one?
https://github.com/Tonnie78/Lua-GPS-Widget
Nov 29, 2019, 08:24 PM
Roger Baroudy
Rogero's Avatar
Originally Posted by 3djc
Out of the 3 ways I know to achieve that, this is by far the one I was expecting least, and also the more difficult. I'm not too sure why anyone would want ACCESS, but congrats anyway
3djc
so there are 2 more ways to achieve ACCESS compatibility (man.. u just broke my heart...) anyway i have no problem doing this mod also, i have the equipment and the skill to do it, and having ACCESS as a plus is definitely nice, will be able to use the new OTA Frsky receivers....
as i understand, the ACCESS upgrade module is needed and the R9M 2019 module to have R9 + ACCESS.
Nov 29, 2019, 10:25 PM
Originally Posted by jessyjames
Hi guys,
Yesterday i did it. I desolder the Proz of my T16 and solder a 32F439 to it.And now the ACCESS upgrade module works in my T16
Here are some Pictures.
OH your going to make someone mad.
Nov 30, 2019, 12:00 AM
Originally Posted by hpnuts
The V911s protocol only works fine for some people with the emulation. It's totally random based on the tolerance you are getting on your module... I think there is a better success rate using the nrf24l01, please test and report.
As of the Esky150 protocol I've reversed it using the F150X remote control. I remember that the binding is quite special and you need to respect a certain timing... I know it was reported to work with other helis. Have you tried to change the option value to switch from 4ch to 7ch? I should have make it a sub_protocol it would have been simpler, may be I'll do that.
Pascal
Seems that v1.3.0.45 breaks V911s for me. I'm no longer able to bind. :-/
Nov 30, 2019, 01:11 AM
junmarD4th's Avatar
Originally Posted by mshagg2
Sort of, but I think it's different.
Sent from my phone.
Nov 30, 2019, 02:22 AM
OpenTX core team
3djc's Avatar
You cannot get R9M 2019 ACCESS on your T16, nor can you on an x10 non express. The 2.4GHz upgrade doesn't change that at all. It requires a diferent wiring of the external module bay
Nov 30, 2019, 03:08 AM
Ben Lye
Way to go, Jumper
I can't share a link to FB here. If you're in the Jumper Technology or Jumper T12/T16 groups you'll see this message. Free USB-to-serial adapters (you pay shipping) for anyone with an original T16 Pro with internal module who can't get a USB adapter to do the module firmware upgrade.
Nice gesture, and nice public acknowledgement of the work by @hpnuts, @3djc, @kilrah, and the rest of the OpenTX team
Nov 30, 2019, 03:58 AM
That one works fine for internal or external flashing of bootloader/firmware. Here is how I connected it to update an external module (with FT232 set to 3.3v and the radio powered off).
Internal modul4 needs the special connector/cable.
Originally Posted by bigsmitty
Hi,
I screwed up and ordered this to update my internal MPM. Can I still use this? Just plug straight into P.C. ?
And where it has a switch for 3 or 5 volts do I wire it the same as the others?
Any help greatly appreciated in advance. Thanks
Smitty
Nov 30, 2019, 07:23 AM
Originally Posted by benzo99
Way to go, Jumper
Now what you have to suggest is that they take out a bluetooth module to install it inside the station, the pcb is already prepared so it is a very simple mod if they wanted to sell this module.
The next thing would be to ask for an internal charger module for the batteries
Nov 30, 2019, 07:29 AM
Way to go, Jumper
Wow, that's really nice of Jumper.
Nov 30, 2019, 08:01 AM
I updated N57 and the quick access when you hold down the return to get to monitor screen doesn't work.
Nov 30, 2019, 08:13 AM
OpenTX core team
3djc's Avatar
I don't believe there was ever such a thing
Nov 30, 2019, 09:05 AM
Yes I used it all the time . it was on N28
Yes when you hold down the return for a second or 2 it went directly to monitor. I used it a lot to check my mixes.
It is not there no more
Nov 30, 2019, 09:32 AM
Beach Bum
Steve FliesLow's Avatar
^ At least there are still two other simple methods to get to monitor, and a second monitor that can always be on main screen or page of your choice.
Nov 30, 2019, 10:23 AM
Happy FPV flyer
Kilrah's Avatar
It's the MDL key you can use to get to the monitor while in the menu, not RTN.
Discussion Jumper T12 Open Source 16ch Radio with JP4-in-1 Multi-protocol RF Module Hobby Porter Radios 735 Nov 07, 2019 03:58 PM
