Nov 06, 2019, 12:08 PM
Originally Posted by dang
"Good luck" is right. They look really nice but I have no idea how I'd print them in anything but rigid material.
Here's a few pics of some that I printed last night.
Nov 06, 2019, 12:37 PM
Originally Posted by hpnuts
Have you followed my frequency tuning page? https://github.com/pascallanger/DIY-...ency_Tuning.md
The important bind being
Pascal
Thanks I'll check it out. I've messed with freq tuning a bit but I think I need to dedicate myself a little harder to it.
Nov 06, 2019, 05:39 PM
Pascal
hpnuts's Avatar
Originally Posted by 52Sabre
And are both of the green and red LED's supposed to be lit on the external MPM?
The multi module LEDs are described in the troubleshooting section: https://github.com/pascallanger/DIY-...roubleshooting
Pascal
Nov 06, 2019, 05:45 PM
casual park flyer
52Sabre's Avatar
Pascal
Thanks. Yes I had read that some time ago but had forgotten due to oldfartitis. Bookmarked.
Sent from my HTC M9 using Tapatalk
Nov 06, 2019, 06:39 PM
lovin' early retired in 2000
bnrusso's Avatar
Nov 06, 2019, 06:44 PM
Beach Bum
Steve FliesLow's Avatar
How do I adjust tension for the throttle with Hall T16? That little screw only adjusts tension for the rudder.
There is a metal strap on backside of gimbal that is split in two, a tensioning screw on each. One is ratchet/indent strength, the other is stick resistance.
Nov 06, 2019, 06:53 PM
casual park flyer
52Sabre's Avatar
Ahh . . OK thanks, I'll check that out. I was wondering if there should be a ratchet feel to the throttle like on other xmtr's.
Nov 06, 2019, 06:59 PM
Fly Planes, Be Happy 😜
ooOoo's Avatar
Originally Posted by danong
Here's observation from my yesterday-arrived T16 Pro Hall
- serial H0149xx
- JumperTx 2.3.0
- internal module 1.2.1.51 (hence still no bootloader)
- sdcard is 1gb
- no loose flying screw
- battery tray balance plug is 3 wire
How do I check my internal module version number? Or how do I know if it has the bootloader already?
Edit: I have 1.2.1.85 would it still need the bootloader?
Nov 06, 2019, 07:35 PM
Pascal
hpnuts's Avatar
HoTT protocol
Thanks to spinner_deluxe for lending me his Graupner radio + RX, the HoTT protocol will be available in the next version of Multi.
It's working with limited functionnality:
  • Support for up to 12 channels.
  • Basic telemetry: RX voltage, Rx temperature, RX RSSI, RX LQI, TX RSSI and TX LQI.
  • Failsafe
  • No RX configuration (sumd, sensors, mixers...) but if for example sumd is configured on the RX, it will stay available once bound with Multi.
Pascal
Nov 06, 2019, 07:36 PM
Waiting for the next clear day
1.2.1.85 should already have the bootloader, but to test, start with the T16 off, hold the aileron trim and the rudder trim towards the center, then power on the T16. It should load into the bootloader.
Tony
Nov 06, 2019, 07:38 PM
Pascal
hpnuts's Avatar
Have you purchased it like this?
If it's really 1.2.1.85 then I guess that the bootloader is in. You can always try to flash the Multi module from OpenTX nightlies (SD card manager) and if successfull the bootloader is in.
Pascal
Nov 06, 2019, 07:49 PM
ooOoo's Avatar
Tony
Pascal
Below is a picture of what I get with the trim tabs in while powering on.
Yes, it's the version that was on the radio when I took it out of the box. I just received it today.
Nov 06, 2019, 07:53 PM
Wonderful news!
Nov 06, 2019, 07:54 PM
stevea3342's Avatar
Was jumper smart enough to flash a multi version that matches their default jumper channel order ?
Nov 06, 2019, 07:59 PM
1000MIGLIA City - Italy
rosnik's Avatar
Originally Posted by 3djc
You should read the section /*** GLOBAL ID ***/ of multi config.h
Interesting...
May you get direct link for dummies?
Discussion Jumper T12 Open Source 16ch Radio with JP4-in-1 Multi-protocol RF Module Hobby Porter Radios 735 Nov 07, 2019 03:58 PM
