Oct 10, 2019, 10:14 AM
FPV Ground Pounder
Gramps50's Avatar
Originally Posted by hpnuts
Two ways:
- Read the module flash, we can guide you for that but you need the exact same tools and process than flashing the module
- Wait for OpenTX 2.3.2 release and try to flash
Pascal
Thanks, my usb adapter came today so I will probably just go ahead and flash to the lastest version then I'll know for sure.
Thanks for all your work on this it is greatly appreciated!!
Oct 10, 2019, 10:18 AM
Originally Posted by Hard impact
Kind of feeling the same thing!
I wanted a high channel "Radio" multi protocol was not important to me, 90% would/will be DSM/2
Radio setup as been a shock BUT all this re-tuning and low output with the internal module upgrade stuff is probably enough for me to sell the T16 on.
The Spektrum i12 should of been my choice.
It transmits as far as my $800 Futaba .I like the tuning feature now. Easy to use and you know it is tuned the best it can be.
I like it I think OTXis going to make this even nicer.
Will OTX turn audio off when not in use like FrSky X10s.
Right now you hear a slight hiss all the time. No big deal just wondering.
Oct 10, 2019, 10:21 AM
3djc's Avatar
Yes OpenTX will mute audio, but what you hear MAY come just from RF bumping your speaker wires, you'll have to see. We have seen significant progress on our radio with the mute tho
Oct 10, 2019, 10:39 AM
landru's Avatar
Since we're taking about audio and OTX...
I asked this in the X10 thread but didn't get an answer: I still get audible hiss under the audio tracks on my X10S with OTX 2.3.1. Am I correct in thinking any possible fix must be in hardware not software?
Thanks for all the good work!
Oct 10, 2019, 10:48 AM
3djc's Avatar
For X10 yes
Pascal
hpnuts's Avatar
Not really... I'm not sure if DSM RF freq tuning is really needed since the reports with the latest JumperTX fw are encouraging. There might be different bugs at play in the radio firmware causing this issues. Like I said before there has never been a need to tune CYRF protocols: DSM, DEVO, Walkera, J6Pro, WFLY... The setting is even disabled by default.
The internal module is not bad in term of mw with DSM.
Pascal
Oct 10, 2019, 10:52 AM
landru's Avatar
Originally Posted by 3djc
For X10 yes
Thank you.
Oct 10, 2019, 12:14 PM
Unscheduled Landing Specialist
bigsmitty's Avatar
The attached version of the JumperTX firmware is the latest version compiled without the channel number DSM bug for the internal module.
For the ones reporting issues with DSM and internal module, make sure to use this fw.
Please report on this version and the fallouts you still see.
Pascal
Installed and bound up 2 dsm receivers. One is dsm2 (not official spektrum) and it works perfectly!
The other is a Blade Nano QX dsmx 11 ms. Also worked perfectly!
Edit: Bound a Horizon Hobby UMX Pitts same results! So far no issues.
Thank you Pascal.
Oct 10, 2019, 12:40 PM
'FPV'er...not a "LOS'er
Vantasstic's Avatar
Originally Posted by goebish
The RTC is built into the STM32F4, I'd check the soldering of the battery slot.
Okay, thank you. The soldering on the battery holder looked good, but I didn't try and trace the voltage down line to make sure it was present there. Might have to open this thing up again...
Oct 10, 2019, 12:41 PM
Fortunately, it is clearly designed to be opened with ease.
Oct 10, 2019, 01:23 PM
Pascal
hpnuts's Avatar
Thank you Pascal.
Great stuff.
Pascal
Oct 10, 2019, 05:51 PM
Flew more packs today. Very happy with jumper. I flew Very far to see how far. I turned around 3 blocks over when my video was getting harry.
No Rssr warning and this is through trees and heavy WiFi area.Jumper performing good with RXSR
Running 500 mw on Video.
Oct 10, 2019, 05:57 PM
Pascal
hpnuts's Avatar
Thanks for the positive feedback!
Pascal
Oct 10, 2019, 07:19 PM
I bought 3 jumpers Willing to sell one. I updated the internal with the latest firmware and bootloader.
The one I am using works like a champ
Bought from Defiance Rc.
Oct 10, 2019, 07:29 PM
Price?
Discussion Jumper T12 Open Source 16ch Radio with JP4-in-1 Multi-protocol RF Module Hobby Porter Radios 735 Nov 07, 2019 03:58 PM
