Mar 03, 2019, 06:18 PM
So, got the plane out to range test Friday and it began exhibiting the original bad behavior. Slow connect, jittery sluggish servos with solid green LED. After a few minutes it started behaving normally and I proceeded with range test. Range test was no good at only like 50 feet.
I swapped with another 8 channel Rx and everything works great.
So, this Rx got fouled up sitting in my shop somehow.
Thanks for your assistance,
Kent
Mar 03, 2019, 10:27 PM
Did you change the transmitter, or number of channels? If so, you have to re-bind the receiver. Is it old receiver firmware without the reboot notification? Are you using a switch? Did you try a straight battery to the receiver? Is the receiver at least 12" off of the ground during a range test? Are you following the range test procedure in this forum?
Mar 04, 2019, 09:17 AM
No change in transmitter or channels
Itís the newer firmware
No switch, plugged directly to the Rx. (Tried two different batteries)
Yes, itís more than 12Ē off the ground
Yes, following the post range test proc
Mar 04, 2019, 11:16 AM
Try doing a RESET to the receiver, re-bind, and then range test it again.
Mar 04, 2019, 04:24 PM
I have already tried that. See my post from 2/26
Mar 04, 2019, 08:56 PM
Do you have a picture of your installation that you can post? Have you tried doing a range test with just the receiver, battery, and a servo?
Discussion FrSky Pro 8-channel receiver (D8 mode) won't bind nvoltex Mini Multirotor Drones 0 Sep 21, 2017 07:29 AM
Help! RacerCube Integrated F3 EVO 4 In 1 20A F396 ESC Frsky 8CH PPM/SBUS Rx bind issue jortner Multirotor Drone Electronics 0 Feb 06, 2017 11:31 AM
Help! Binding Issue (Orange DSMX Rx + Spektrum DX7s) aitee Radios 4 Apr 19, 2016 07:52 PM
Discussion Tx and Rx binding issues flyrcehelis Radios 3 Jun 16, 2009 11:19 AM
