Feb 23, 2019, 06:41 AM
robertus's Avatar
Build Log
JEPE F-16 90mm highly modded for 4S/70mm setup
I know it is not common setup, most of them are on 6S.
Can someone suggest me a 4S motor for 80 or 90mm EDF for thrust around 2kg/70oz?
Feb 23, 2019, 10:00 AM
What plane are you putting in into? Can you modify mount and fit a 70mm edf instead?
For a 2Kg thrust, you'll need atleast 6s on 90mm edf to keep you amp down.
Feb 23, 2019, 10:15 AM
robertus's Avatar
I want to put this setup in F-16 From JePe. This kit is dedicated for EDF 90, and in full setup it weights around 3kg. I want to build it as light as possible and stay with 4S. I have EDF70 setup on 4S from FMS but it has around 1,4kg of thrust. I need a little more, around 2kg of thrust to push JePe F-16, I think it will be better.
http://www.jepejets.com/jepeshop/sal...t-version.html
Minimal configuration (just foam) weights 850g, so I hope I can build this plane in weight to fly less than 1,6kg based on 4S setup.
Feb 23, 2019, 09:47 PM
Try this:
ecalc.ch
Btw: i have the same kit as yours coming. Going to power it with 90mm edf in 8s 5000mah ( 2x 4s 5000)
Feb 24, 2019, 03:25 AM
robertus's Avatar
Thanks guys. In the meantime I found interesting setup.
https://www.motionrc.com/products/fr...-for-80mm-a-10
It is also interesting option.
I prefer light planes because I can launch them by hand.
For example my MiG-29 with one EDF weights only 1,6kg instead of 2,7kg similar size MiG on the market.
Added how JePe F-16 looks like.
Feb 24, 2019, 10:54 AM
Foam addict
4stripes's Avatar
The link you posted is for a FW motor only. The shroud will not fit other types so you would be stuck with their 6S motor.
Personally, I would go minimum 90mm 6S even for hand launch. I have the same model on wheels and it needs a 7S setup to get decent performance.
It will "fly" on 6S but on 7S it moves!
Feb 24, 2019, 12:00 PM
robertus's Avatar
Here you have Fan with motor
https://www.motionrc.com/collections...-w-3525-2870kv
Everyone advice me to go to 6S
Feb 24, 2019, 12:14 PM
Foam addict
4stripes's Avatar
That will not fly. Unless you can launch downhill and keep going.
May 11, 2019, 05:00 AM
robertus's Avatar
I'm glad to say, that 4stripes owes me beer.
JEPE F-16 90mm highly modified for 4S (5 min 5 sec)
Some technical specification.
Setup is:
EDF 70mm changesun,
accu-4S 3000mAh
ESC: Blueseries 70A
Motor: Turnigy L2855-2800
Weight to fly 1650g/58oz
Max thrust for this setup 1100g
May 11, 2019, 07:35 AM
Kevin Cox's Avatar
Nicely done Robertus!
May 11, 2019, 08:24 AM
https://youtu.be/tPdv6jHDCRo
Setup is:
EDF 70mm changesun,
accu-4S 3000mAh
ESC: Blueseries 70A
Very nice.
But like some said, maybe better
With 6s to get some more power to do
Basic ACM ... loops, Cuban 8 and the likes :-) .
6 S 13 blade XRP 2200kv might get 1800gr of thrust and your F16 will be around 1800gr too.
So it will be a nice 1:1 Thrust to weight ratios
For performing fun.... Just me though.
Nice ;-)
Question. Did you narrow down the stock
Exhaust for 70mm fan ? Like 61mm diameter???
May 11, 2019, 08:44 AM
robertus's Avatar
Ah yes, yes, more power is better, as usually
For me probably 6S setup with 70mm EDF would be better for speed and vertical manoeuvres, and for hand launch as well, but this project is kind of "can I do it?", or "It will not fly! It will, hold my beer!" I like challenges.
Moreover I don't have any part of 6S setup so this is also cheapest version at the moment. Who knows, maybe I will upgrade her, because even on this setup she flies very nice and smooth.
About mods, first of all I cut and slimmed down foam kit from 850g to 700g. Then rearranged EDF position for better CoG balance, and yes I had to create dedicated thrust tube for 70mm EDF.
Thanks for your 6S config.
Bellow examples, where I cut the foam.
May 11, 2019, 08:50 AM
robertus's Avatar
red- original position for 90mm EDF
green- position for 70mm EDF
You can also see how many foam I cut - a lot of them - but still rigid for my setup.
May 11, 2019, 08:55 AM
Wow, very nice ducting work.
I admire your spirit " Can I do it "
How far back did you move your 70mm fan?
Oh , I just saw the photos.
Thanks.
Discussion YAK130 90EDF Jet siemenliu Electric Ducted Fan Jet Talk 2 Oct 23, 2013 01:12 AM
Question F 18 F version 90edf ? DamonSchumi Electric Ducted Fan Jet Talk 4 May 04, 2012 01:51 AM
Discussion Hobbywing 80 amp esc performance on 4s vs mamba monster on 4s tiforce Off-road Cars 0 May 02, 2012 05:45 PM
