1/18 Yeti Jr Can-Am Maverick X3 4WD
This 4x4 Yeti Jr is ready for fun right out of the box. It has an independent suspension like it's bigger brother with a floating solid rear axle for better handling, increased clearance and improved stability at higher speeds.
The Popular Yeti Shrinks to 1/18th Scale
This 4x4 Yeti Jr is ready for fun right out of the box. It has an independent suspension like it's bigger brother with a floating solid rear axle for better handling, increased clearance and improved stability at higher speeds. The officially licensed Can-Am Maverick X3 body makes this thing stand out. It looks awesome and is set to offer a ton of value at only $149.99.
Check out the 1/18 Yeti Jr Can-Am Maverick X3 4WD Here
Features:
  • Licensed Can-Am Maverick X3 body and wheels
  • Licensed Maxxis Bighorn 2.0 tires
  • Spektrum STX2 2.4GHz transmitter
  • Spektrum waterproof ESC/Receiver Combo
  • Dynamite 37T brushed electric motor
  • High-torque metal gear servo for rough offroad conditions
  • AR18 solid rear axle with ample ground clearance
  • Adjustable coil-over shocks
  • Three-linked rear suspension for improved handling
  • Independent front suspension for high speed stability
  • Rear hinge body mount system
  • 48P gears give you more possible configurations
  • Adjustable motor mount and easy access chassis
  • Full vehicle ball bearings
  • Adjustable battery tray
  • Centered rear driveshaft for efficiency
  • Easy to Use USB Charger Included
Feb 23, 2019, 10:51 PM
www.gunnphotoservices.com
Matt Gunn's Avatar
Its about time a scale SxS was done! Looks legit!
Latest blog entry: www.gunnphotoservices.com
Feb 25, 2019, 02:11 AM
Panhead5496's Avatar
Very cool!!
Now if only they would release the same thing in 1/10 scale
Feb 25, 2019, 12:11 PM
Originally Posted by Panhead5496
Very cool!!
Technically, that is 1:10 scale. Side-by-Sides are significantly smaller than trucks & SUVs.
The one big issue with this release is that the Can Am doesn't have a solid rear axle.
Mar 04, 2019, 02:05 AM
Valiant Poultry
Gimpdiggity's Avatar
I ordered one of these. Should be here by Wednesday at the latest.
Though the solid axle isn’t really scale, I love the overall look of it. I’ve been without a trail truck for a while now...I wasn’t really using them much...but I plan on using this out on the trails. There isn’t really much “crawling” out there, so the open diffs shouldn’t be an issue.
I’ve read it gets about 15 minutes of “bashing” with its 1300mah battery, so I’m hoping to get 45 minutes of low speed trailing with a 2200mah LiPo I have.
New Product Axial Yeti Jr. RTR 1/18 scale Rock Racer SD One. Rock Crawlers 17 Jun 19, 2017 02:36 PM
News Axial Racing Yeti Jr. 1/18 Matt Gunn Off-road Cars 24 Feb 03, 2017 08:27 PM
Review Hobbico's Dromida 1/18 Wasteland 4WD Truck and 4WD Buggy RTR Combined Review Michael Heer Off-road Cars 6 Feb 26, 2016 04:18 PM
News Axial Yeti XL 1/8th Scale Electric 4WD Jim T. Graham Off-road Cars 20 May 11, 2015 07:50 PM
