Feb 22, 2019, 08:30 AM
Play that funky music right
kenh3497's Avatar
Modifying rotating retracts to non rotating for Zlin 526 possible?
I will be restarting a build of a 20% Zlin 526. The wheels retract strait back with out rotating. I need the retracts to have a 95 or 100 degree sweep. A normal retract turned 90 degrees will work fine but the retract angle complicates thing a bit as I can't find anything as it seems everything is 90 degrees only. This should be about a 10 or 12 pound airplane when finished.
Rotating retracts seem to be readily available in the 95 degree range. Can the rotating feature be disabled? That would open up a wide range of retracts to use.
Thanks in advance!
Ken
Feb 22, 2019, 10:16 AM
Build a scale plane already!!!
scale_only's Avatar
Nose gear come in more angles, just use two of those and lock the steering?
Mar 01, 2019, 09:13 AM
-insert witty saying here-
Hemikiller's Avatar
Agreed. The Robarts have a trunion similar to a strut-ready retract with the steering bearing clamped inside. Looking at the drawing, it seems you can remove the bearing and use standard struts.
https://cdn.shopify.com/s/files/1/03...0RSSP.pdf?3710
Probably best to give them a ring and get their thoughts.
Article Great Planes Zlin Z-526 Review gp125racer Sport Planes 30 Jun 26, 2020 02:03 PM
Question BPLR's Zlin 526 Akrobat wildpalms Slope 4 Feb 13, 2005 04:04 AM
Zlin 526 3-View fellside Scale Kit/Scratch Built 22 Feb 04, 2005 03:26 PM
Pilot models Zlin 526 gbruce Sport Planes 9 Aug 14, 2002 08:05 AM
