Feb 20, 2019, 07:13 PM
1/10th Tacon Pursuer On Road Car Brushless Ready to Run (Black) RC Race Car
Fast Tacon Pursuer On Road 1/10 Brushless Race Car (1 min 16 sec)
https://www.nitrorcx.com/25c006-10-p...brushless.html
The Tacon is a 1/10 scale on road car . It was designed from the ground up with pure performance in mind. Performance features derived from 1/8 scale vehicles have been shrunken down in size and engineered to deliver the utmost performance in a small on road car package. A 2mm thick aluminum chassis serves as the base of this on road car. Mounted on the front and rear is 2.5mm thick 6061-T6 anodized aluminum shock towers towering over the metal geared fluid filled differentials. Attached to the robust towers are aluminum threaded oil filled shocks providing plush and ground hugging dampening. The steering tie rods and upper and lower arms are adjustable for fine tuning of the toe and camber, effectively altering the handling characteristics of the car.
This car has awesome power to weight ratio. Weighing in at slightly over 2 lbs, the vehicle is easily propelled by the 380 sized 4500KV brushless motor. A 80 amp programmable brushless electronic speed controller delivers the current efficiently through an included 7.4v 3800mah LIPO battery. All of this power transfers through a shaft driven four wheel drive system providing ground clawing action through the performance wheels and rally spec tires.
The Tacon ready to run package also includes a 2.4ghz radio system. With frequency hopping technology, interference is a thing of the past. No longer do you have to worry about your specific channel. The radio system will automatically take care of that for you while you are focused on handling this beast of a machine.
With a body designed with on road car looks and aerodynamic performance, combined with a roof spoiler on the rear hatch. This scale on road machine will put a huge smile on your face when you see it four wheel power sliding through a corner spitting dirt and debris out the rear end.
Features:
1. Tacon design 1/14 rally tires
2. Tacon design slipper pad with adjustable gear cover
3. Aluminum-threaded, oil-filled, coil-over, 6061-T6 ajustable shocks
4. 2.5mm 6061-T6 aluminum shock towers
5. Front and rear metal gear differentials
6. 80A programmable ESC, Lipo 2S/3S compatible.
7. 4 pole 6.5T 2850 4500KV brushless motor
8. 4WD shaft drivetrain
9. Adjustable mini servo with saver
10. Steel hinge-pins with rounded front bumper
11. Tacon receiver with 2.4GHz technology
12. 7.4V LIPO 3800mAh battery with 3.5mm gilded round connectors
13. 2.5mm anodized aluminum rear and front kick-up chassis with dirt guards
14. 12mm wheel hexes
Specifications:
Scale: 1/10
Length: 430mm (17in)
Width: 190mm (7.5in)
Height: 120mm (4.7in)
Wheelbase: 250mm (9.85in)
Weight: 1.3kg (2.8lbs with battery)
Tire Type: Tacon Rally Tread
Chassis: 2.0mm anodized aluminum
Motor or Engine: 4500Kv 2850 brushless motor
Gear ratio:8.23
Speed Control: 80A Brushless
Radio: 2.4GHz Technology
Batteries: 7.4V LIPO with 3.5mm gilded round connector, Charger not included
Shock Type: Aluminum-threaded, oil-filled, coil-over, 6061-T6 ajustable
Ball Bearings: Complete
Package Contents:
100% Assembled
1x 1/10 Tacon Pursuer
2CH 2.4Hz Transmitter and receiver
1x Battery Charger (100-240V)
1x 7.4v 3800mAh LIPO battery
1x Instruction Manual
Required to Run:
AA Batteries for Transmitter
LIPO Charger
Mar 27, 2019, 07:33 PM
Tacon Pursuer
My new rc car should arrive 3/28
Will unbox over the weekend and test drive
Review to follow.
Mar 29, 2019, 08:53 PM
Tacon Pursuer
Pursuer came on Thursday, just 7 days after ordering from NitroRCX.
Opened the box and for 239 bucks I am quite impressed as I was with my Tacon Rally Ranger witch I've had now for two years and is still going strong. Right from the beginning I geared up my Rally Ranger two teeth and put in a 3s lipo, this is how I run it with no problems other than the stock body is very brittle in the cold, (hit a car tire and the body just exploded in to 6378 pieces, well I don't know how many pieces it was but it was a lot). I plan on running the Pursuer over the weekend. I can't believe how well made this is. RTR with a 7.4v lipo (I believe the body is of better quality on this one). The esc is 80amp programmable...really! That's awesome (can we say 6s lipo ?). Aluminum chases, upper stifner, and shock towers, oil filled coil over aluminum shocks, and as with the Rally Ranger there is mounting points for sway bars.
Life is good for this old man with nothing better to do than blow his wad on a little car
Yesterday, 06:57 PM
Have fun!
Discussion 1/12th Tacon Ranger Blue Rally Car Brushless Ready to Run RC Remote Control Radio Car Nitro_Nancy NitroRCX 0 Sep 25, 2018 03:02 PM
Discussion Tacon 540XL 2848 Brushless Motor 4300KV for 1/10 On-Road RC Race Car Nitro_Nancy NitroRCX 0 Jul 13, 2018 03:07 PM
Discussion Tacon 2040 Brushless Motor 4120KV for 1/16 & 1/18 On-Road RC Race Car Nitro_Nancy NitroRCX 0 Jul 13, 2018 02:51 PM
Discussion Tacon 2030 Brushless Motor 5200KV for 1/16 & 1/18 On-Road RC Race Car Nitro_Nancy NitroRCX 0 Jul 10, 2018 04:24 PM
Discussion 1/12th Tacon Blue Ranger Rally Car Brushless Ready to Run RC Remote Control Radio Car Nitro_Nancy NitroRCX 0 Mar 29, 2018 03:19 PM
