This thread is privately moderated by Mr Tim, who may elect to delete unwanted replies.
Feb 18, 2019, 01:20 PM
1/2 A Shrike
Brought this at swap meet. What type of paint did they use and what BL motor to use how to mount. Any help , thanks
Feb 19, 2019, 03:40 AM
eagle60's Avatar
I do not know about the paint and it is difficult to guess from pictures, but regarding motor I can say that it depends on how fast you want it to fly. First you should estimate the flying weight, then select a motor with thrust between 1.2 and 1.6 the weight ( 1.2 for slow and 1.6 or more for fast) considering that you can get 2.4 to 3 grams thrust per watt according to efficiency of motor in its working conditions. For slow flight less cells, less rpm (it is not said less kv) and bigger prop. For fast flight more cells, more rpm and smaller prop. Check in my blog the shrike type model I made. I am now planning to built a smaller one electric with 32" (80cm) wingspan with goe445 with thickness reduced to 3.6% airfoil and I am planning to use a T-motor F80 2500kv with 6s and dont know which prop yet (I want to stay around 37-39A). Finally beware of CG position: place all components in order to avoid ballast to balance it.
Discussion HEPL GETTING 1/2A, 10-15, and 40 size Shrikes plans MW4DREAMMAKER 1/2A Planes 16 Dec 12, 2016 03:27 PM
Build Log Shrike 1/2 or speed 400 3 cell 130mph set-up Team Astro High Performance 11 Oct 28, 2007 03:32 PM
Download uploading video - BruceL, Mehrdad - Shrike, Trinity, Mach 1, full scale x4 infopimp Slope 22 Sep 04, 2007 06:47 AM
what kind of motor for 1/2a shrike? sylentbob3 Power Systems 0 Jul 27, 2005 02:01 PM
Electric 1/2A Shrike snsmith Electric Plane Talk 15 May 26, 2003 11:28 PM
