This thread is privately moderated by Scale Master, who may elect to delete unwanted replies.
Feb 18, 2019, 05:54 AM
Trader Rating: 19
Scale Master's Avatar
$80.00 USD
Seller Pays Shipping
Sold
ZTW Gecko 150A ESC OPTO High Voltage
Used 150Amp Speed High Volt control for EDF up for grabs. Motion RC sells them new for around $120. You can get this used one that works perfectly / no damage for 40 bucks less.
Details:
ZTW Gecko 150A ESC OPTO High Voltage (HV) - ZTW4150401
This ZTW Gecko series ESC is a high-quality, efficient brushless electronic speed control. It can operate without the need for a separate receiver battery to power your servos and receivers saving you weight and simplifying your electronic connections (but a separate BEC is required, see below). The Gecko series includes an aluminum heat sink body which is lightweight and helps dissipate heat more efficiently. If you are looking for a top of the line, full-featured ESC at a competitive price, the ZTW Gecko is the logical choice.
Features:
Data logging system such as temperature, voltage, current, and RPM
Advanced Governor Mode and soft start
Power arm protection, over-heat protection, low-voltage protection and lost-signal protection
Secondary sub-menu setting by the LCD program card or your PC
Super smooth and accurate throttle linearity
Support for most motors, including high RPM motors
Programmable motor timing
Utilizes new smaller MOSFET technology to minimize weight
Aluminum finned heat sink
Programmable throttle input range
Anti-spark circuitry (on HV OPTO models only)
ESC firmware and program settings can be updated via PC connection (USB adapter sold separately)
Includes:
Pre-installed EC5 Connector (power connector) and 5.5mm bullet (motor connector) for your convenience
Requires:
ZTW 10A BEC/UBEC - ZTW300200010
Optional:
ZTW LCD Programming Card - More Info
WiFi Programming Module - More Info
Free shipping to CONUS
Paypal address for payment is: [email protected] (if sending payment please send as friend and family to save money on the fees)
Feb 18, 2019, 07:27 PM
Trader Rating: 34
msonny35's Avatar
I will take if 8 cell or better
Feb 19, 2019, 01:58 AM
Trader Rating: 19
You Got it
Feb 23, 2019, 09:32 AM
Trader Rating: 34
msonny35's Avatar
money sent for esc ship to same addres.thanks…
Trader Rating: 34
msonny35's Avatar
Sold ZTW Gecko 150A ESC OPTO High Voltage - sale pending bw762qx Aircraft - Electric - Power Systems (FS/W) 0 Oct 24, 2018 01:39 AM
Discussion ZTW Gecko 150A High Voltage Aircraft ESC ztwoem FPV Equipment 0 Aug 26, 2017 02:48 AM
