Feb 18, 2019, 03:06 AM
Question
Servo Chatter
Hi Jim,
I have a X24 v1.5 in a 3.1 CompArf 330. Using (2) 5600 7.4v LiPo batteries regulated to 6.0v and (2) DMSS XBUS DFA RG812BX receivers with sub-receivers.
Single JR 8711 servos with 2" arms on each elevator surface, the right one has a constant chatter. I was going to replace the 8711 with a MKS 777A to see if that clears it up.
Any ideas?
Thanks!
Keith Roberts
Feb 18, 2019, 11:31 AM
Is this just sitting idle, or with an engine or motor running? Try swapping servos elevator ports (so left goes to right and right goes to left). If the chatter follows the swap then the problem is definitely the servo. The X24's servo outputs are insanely precise, and all occur at the same time. ALL of the servos would be chattering if there was a problem with the servo output itself. Be aware though that it seems that MK 777 servos have a problem with gas ignition systems.
Why are you using a regulator? The X24 was designed for the very purpose of getting rid of regulators. You are really defeating the entire purpose of the X24 by using a regulator. If you need 6v for your servos, get rid of the Lipos and use LiFe instead. LiFe is a much better technology anyways, safe to charge in your aircraft (no fire potential ever), faster charge, etc.
Feb 20, 2019, 07:26 AM
Thanks Jim,
I'll switch the elevator leads and see what that yields. Need 6v for the servos so maybe LIFE is a good remedy too. Had not heard that about 777 and ignition systems.
Keith
Mar 09, 2019, 10:06 PM
Thermals, Tom
RyanNX211's Avatar
You could also try another system to see if the servo is still affected.
Tests with carbon plates in the firewall or faraday shields are not
recommended for flight but could yield some interesting observations on the ground.
Latest blog entry: Steak and Old Timers
Discussion New servo chatter Kirwin Radios 2 Jan 01, 2016 03:06 PM
Tx off, servos chatter, Tx on, quiet servos, no response! squidbait Electric Plane Talk 2 Jul 26, 2005 07:15 PM
Servo Chatter Red Baron 47 Power Systems 10 Jun 10, 2001 12:07 AM
GWS Pico Receiver & Servos (Crazy Chatter...No Response) martin johnson Electric Plane Talk 9 Jun 09, 2001 03:11 PM
