This thread is privately moderated by bnrusso, who may elect to delete unwanted replies.
Feb 17, 2019, 09:47 PM
early retired & loving it
problems with IrangeX 4in1 (not plus)
2/18/19
I am ordering a new FTDI to see if that may be the problem.
______________________________
I changed Boot0 from horizontal to vertical and got further than before.
After
Looking for Maple device ...
No Maple devices found.
Probing serial port COM7 for STM32 in BOOT0 mode ...
stm32flash 0.4
http://stm32flash.googlecode.com/
Interface serial_w32: 115200 8E1
Version : 0x22
Option 1 : 0x00
Option 2 : 0x00
Device ID : 0x0410 (Medium-density)
- RAM : 20KiB (512b reserved by bootloader)
- Flash : 128KiB (sector size: 4x1024)
- Option RAM : 16b
- System RAM : 2KiB
Found module on COM7
Flashing module via FTDI adapter on COM7
Erasing ...
stm32flash.exe -o -S 0x8000000:129024 -b 115200 COM7
stm32flash 0.4
Version : 0x22
Option 1 : 0x00
Option 2 : 0x00
- Option RAM : 16b
- System RAM : 2KiB
Erasing flash
Writing bootloader ...
stm32flash.exe -v -e 0 -g 0x8000000 -b 115200 -w C:\Users\HPA855\AppData\Local\Arduino15\packages\m ulti4in1\hardware\STM32F1\1.1.0\bootloaders\Multi4 in1\StmMulti4in1.bin COM7
stm32flash 0.4
Using Parser : Raw BINARY
Version : 0x22
Option 1 : 0x00
Option 2 : 0x00
- Option RAM : 16b
- System RAM : 2KiB
Write to memory
Wrote and verified address 0x08000100 (3.13%)
Wrote and verified address 0x08000200 (6.26%)
Wrote and verified address 0x08000300 (9.39%) Failed to read ACK byte
Failed to write memory at address 0x08000300
Writing Multi firmware ...
stm32flash.exe -v -s 8 -e 0 -g 0x8002000 -b 115200 -w C:\Users\HPA855\AppData\Local\Temp\arduino_build_3 00928\Multiprotocol.ino.bin COM7
Failed to init device.
stm32flash 0.4
Done.
2nd attempt with a different USB cable.
Sketch uses 84396 bytes (69%) of program storage space. Maximum is 120832 bytes.
Global variables use 4248 bytes (20%) of dynamic memory, leaving 16232 bytes for local variables. Maximum is 20480 bytes.
stm32flash -o -S 0x8000000:129024 -b 57600 COM7
stm32flash 0.4
Interface serial_w32: 57600 8E1
Version : 0x22
Option 1 : 0x00
Option 2 : 0x00
- Option RAM : 16b
- System RAM : 2KiB
Erasing flash
stm32flash.exe -v -e 0 -g 0x8000000 -b 57600 -w C:\Users\HPA855\AppData\Local\Arduino15\packages\m ulti4in1\hardware\STM32F1\1.1.0\bootloaders\Multi4 in1\StmMulti4in1.bin COM7
stm32flash 0.4
Version : 0x22
Option 1 : 0x00
Option 2 : 0x00
- Option RAM : 16b
- System RAM : 2KiB
Write to memory
An error occurred while uploading the sketch
Discussion iRangeX IRX4 Plus with DSM2 or DSMX Dave_K Radios 3 Mar 08, 2019 04:49 PM
Discussion Inductrix FPV+ with QX7 & Irangex plus Driftkid9 Multirotor Drone Talk 2 Jan 27, 2019 10:45 AM
Discussion How Do Other Switches Work With iRangeX Plus Module? Scrench Multirotor Drone Electronics 0 Feb 02, 2018 05:30 PM
Discussion Problem with iRangex FS-RX Receiver on Betaflight whiskeyx Beginner Multirotor Drones 0 Jun 20, 2017 09:27 PM
Question BCX short flight times...can it be 4in1 problem? its not battery or motors duganderson Coaxial Helicopters 16 Mar 06, 2006 02:23 PM
