Feb 16, 2019, 12:32 PM
Youtube channel : solentlifeuk
solentlife's Avatar
Build Log
Completely scratch Avro Vulcan
For a long time I have wanted to build a Vulcan. With winter being such an awful one this year - I have been able to build two ... yes TWO of my fav birds :
DH Mosquito ....
and now the Avro Vulcan.
2826 2200kv motor / prop ~300gr fully sheeted
Additions (wheels, legs, 3D nose, servos, Rx) ~170gr
3S LiPo from 160 - 190gr depending on which needed to balance out.
That makes her ~ 660gr all up ... which given the wing area is not so bad ...
Span 850mm (I did intend 1000mm but in the end made all fit the sheet)
Root chord 430mm incl intake
Wing area ~27sq dm
LOA incl prop boss 770mm
CoG is calculated at 410mm from nose (170mm from wing intake to fuselage joint)
eCalc gives it excellent figures ... taking a 2200 3S LiPo ... 6x4 APC E prop
C rating 9C (means no high power LiPo needed)
Mixed flight time 11mins
Max E Power out 203W
Thrust to weight 1.3 : 1
Pitch speed 118kph
Vertical climb 31kph
After checking and that narrow nose ... revision is to 1500 3S and she has come in at 660gr with all the gear in incl. LiPo ... Gyro ... and fixed U/C ...
Feb 17, 2019, 02:54 AM
TheGuv's Avatar
Very nice indeed.
Feb 17, 2019, 09:58 AM
solentlife's Avatar
Painted and waiting maiden ...
Feb 17, 2019, 10:59 AM
TheGuv's Avatar
I'm liking that a lot!
Feb 17, 2019, 12:05 PM
solentlife's Avatar
Now to find a way to mount my Soloshot Tag on it ...
Thinking to cut a hatch over the CoG and have a mount with velcro ... then hinged hatch with magnet over top.
Feb 17, 2019, 01:31 PM
solentlife's Avatar
Hatch cut over the CoG and SS3 mount fitted ...
Hatch has magnet but SS3 tag is velcro'd to the mount ..
It was all touched up with paint after photos ...
Feb 19, 2019, 02:27 PM
solentlife's Avatar
Today I decided to swap out the LONGGGGGG U/C legs for the shorter Stinger legs supplied with the mounts. This means that the rear prop hits the deck at about 20 deg nose up ....
So taking the suggestion by another ... I fashioned a rear skid hot glued in front of the prop. When the nose lifts and tail sits down on take-off - the skid will hit ground first ... its longitudinal so it should slide ok,
It does mean of course no Vulcan steep climbs from take-off ! At least not until she's clear of the deck !
Apr 05, 2019, 09:51 AM
solentlife's Avatar
Hoping to let her loose over Latvia this sunday if weather plays ball ...
May 12, 2019, 10:49 AM
solentlife's Avatar
Finally !!
Cirava 11 May 2019 Vulcan success SS3 A (5 min 43 sec)
Cirava 11 May 2019 Vulcan success (6 min 37 sec)
Ok she goes home broken ... but the concept works and has spurred me on to do a better model ...
Considering larger so I can put retracts and to be honest I think a tractor prop up front to get around that high angle she needs to rotate to on take-off.
The model had to have small prop as a pusher to avoid hitting the deck on rotation ... in the end I needed a wire skid ....
May 12, 2019, 12:59 PM
An itch?. Scratch build.
eflightray's Avatar
Nice one.
But you really do need to mow your tarmac
Ray.
May 12, 2019, 01:10 PM
solentlife's Avatar
Normally we drag an old tractor tyre behind a car ... but last year and this not.
For the Soviet Migs ... it wasn't a problem
My Vulcan has some errors that next will fix ... U/C too close together allowing her to topple to one side ... underpowered due to smaller prop to not strike ground on take-off .... spindly U/C that flex's too much.
I'm toying with just going flat plate wing with box fuselage and tractor prop ... then I can hand launch / not worry about ground strikes etc.
I did toy with idea of twin 50mm EDF's or maybe 4x 30mm's ....
May 12, 2019, 05:54 PM
Space Coast USA
hoppy's Avatar
Good show - flew nicely for first time in the air.. First flight is the hardest, for me anyway. Looks like it just ran out of air speed at the end.
May 13, 2019, 02:46 AM
solentlife's Avatar
Dunno ... I've slowed the video to try and see ... what I remember was bring her round to make a run for the runway ... wind was very light and fickle so landing direction was what I decide ... she just rolled over and dived.
Maybe she was slowing down over the last 100 yards or so and finally just decided enough ? I had moderate throttle on which she had flown in earlier part - but only for a few seconds ...
I'm now building another flat plate version as a second tester .... before I go for a large one ...
I think in terms of building full fuselage / wing form - it has to be large ... in the small size I made - its asking a bit too much ...
May 15, 2019, 06:29 AM
solentlife's Avatar
Prop in slot with plenty CF spars..
Added longitudinals as the rear flexed too much after cutting the slot ...
Even that didn't cure it - so added vertical shallow bulkhead both sides ..
Thought the 3D exhausts added character ..
Ready to go .. 430gr AUW incl 1800 3S .. 2200kv wth 6x5 ..
Jun 08, 2019, 08:23 AM
solentlife's Avatar
Flat plate Vulcan 08 June 2019 Maiden (2 min 17 sec)
I could kick myself for not putting reflex before launch !
Anyway - walking across field to collect her - stepped into hole and twisted my ankle - its really swollen up now and boy does it hurt.
But main point is she flew very well ... just a pity that crash was down to my own stupid eagerness to get her back in the air without fixing that nose better.
But she WILL fly again ...
Build Log Avro Vulcan in foam board from Model Aviation DuPageJoe Foamies (Scratchbuilt) 39 Mar 17, 2019 12:46 PM
Discussion A Giant Scale Jet Worth Seeing 1/5 Scale Avro Vulcan Chophop Fuel Plane Talk 0 Jan 26, 2017 11:36 AM
