Feb 16, 2019, 12:26 AM
Racing Enthusiast AMA 3557
JetMech2002's Avatar
Need info on the Super-T quickie 500
Picked one up at a swap and need some info from the plan. The elevator cable seems loose, and wonder how it is supported in the plan, also need the recommended CG. Any help is appreciated!
Feb 19, 2019, 11:55 AM
I'd start with a CG of about 2 3/4" back from the leading edge - you might be able to move back a little from there, but it ought to be a good safe place to start.
Can't comment on the pushrod tube, though.
Jul 21, 2019, 09:29 PM
c/f
c/f
oops
Latest blog entry: Amt 180
Help! Info needed on mixing down elevator when flaps are down on my Futaba 7C joe1 Radios 5 Jul 12, 2018 06:06 PM
Discussion Need help, need info on LA County's first drone dalbert02 Model Aircraft & Drone Advocacy 2 Mar 29, 2017 06:45 PM
Discussion Planning on making a Y6 hex. Info on carbon tube arm diameter needed.... rcminiman Scratchbuilt Multirotor Drones 4 Mar 03, 2016 07:58 AM
Discussion Super Tigre G 500 Quickie infos stg61abc Pylon Racing 2 Nov 26, 2010 01:53 PM
Info needed on the Rutan Quickie Mike Hall Modeling Science 12 Apr 16, 2004 05:21 AM
