This thread is privately moderated by Blaze0021, who may elect to delete unwanted replies.
Feb 15, 2019, 11:04 PM
Blaze0021's Avatar
Video
Eflite Extra 300 1.3m BNF Basic Maiden Flight with GoPro Drone Chase
In 1080p 60fps - Best viewed in fullscreen. This is the maiden flight of my Eflite Extra 300 1.3m wingspan BNF Basic. Not only is it my first flight with this amazing machine, it's also my first time being chased and recorded by a drone (thanks Jeff). Given that we aren't pros I think it turned out pretty well!
Eflite Extra 300 1.3m BNF Basic Maiden Flight with GoPro Drone Chase (4 min 7 sec)
My Eflite Extra 300 1.3m is completely stock. Powered by a Pulse 4S 2250mAh 45C lipo, weighing in at 240 grams. CG was set rearmost to 100mm from the leading edge of the main wing at the fuselage. Flight Timer was set to 3 minutes as recommended by the manual. Flown with a Spektrum DX8 G2 Transmitter at 100% rates and 30% expo on all control surfaces.
Jeff's Drone is a Diatone GT-M530, Ethik S3 props, Frisky R9M Rx, VAS Ion antenna, Frisky Taranis Tx with R9 Long Range Module, GoPro Session 5.
Thanks for the video capture Jeff!
And as always, thanks for watching!
Mar 30, 2019, 02:33 PM
Thanks for the review. Finishing mine up. How dow did you route the antenna?
Apr 01, 2019, 10:41 AM
Blaze0021's Avatar
Mine is the BNF Basic version and the RX was already in place situated in the underside belly of the fuselage . All I had to do was straighten the dual antennas so that they were 90 degrees from each other (see attached photo) and secure them with tape. So long as they’re 90 degrees from each other you’re maximizing the effectiveness of the reception.
Does this help?
Review Horizon Hobby E-flite Piper Cherokee 1.3m BNF Basic Hiflyer Scale ARF/RTF 1 Jun 23, 2019 08:43 PM
Discussion Extra 300 3D 1.3m BNF Basic with AS3X & SAFE Select (EFL11550) DC1138 Electric Plane Talk 4 Jan 10, 2019 06:43 PM
