Aug 17, 2019, 07:20 PM
Slowly making progress
There is no rush.
Aug 17, 2019, 09:45 PM
Tugs & Bugs
Amazing!
Aug 19, 2019, 12:09 AM
This thing is difficult.
Aug 30, 2019, 06:28 PM
Wired up and ready to go with no leaks. Im gonna try test it out this weekend.
Sep 02, 2019, 09:26 PM
Disaster!!!!
Put it on the pond today to test it out.
First run had weight in the back to put the cg 16" from the stern. (Boat is 48")
Not bad but kind of slow and it.looked like the back was low in the water:
Aphrodite with weights (1 min 41 sec)
So I took the weights out and tried it again. It ran a lot faster but after a short while I could tell something was wrong.
I brought it in, took the cabin off and it was full of water. Then the esc burst into flames hahahahahaha.
Maiden voyage, Aphrodite (1 min 46 sec)
The top side pieces the boat don't fit right, large gaps, and I just had them taped on for a test run. Watching the second video it can be seen a lot of water splashed into the boat.
I can make the top pieces fit, but that's not my problem, the water will still get in because it's not sealed around the cabin.
Back to the drawing board. Ssuggestions welcome.
Sep 03, 2019, 05:38 AM
Jerome Morris's Avatar
Once you seal the deck to the hull most of the water issue should resolve itself.
Then see how much water comes thru the cabin / deck gap.
It may not be enough to worry about.
Sep 03, 2019, 07:53 AM
Latitudes vs Attitudes
Bob Gaito's Avatar
Too bad the real Aphrodite didn't have a spray rail (or did it?) -that's what the model needs to keep the water from wrapping around the smooth hull...at least from 1/3 from the stem to the transom. If you want to hide it, it looks like you could get away with putting it just below the waterline
Latest blog entry: Mark V Navy Seal SOC
Sep 03, 2019, 10:02 AM
tghsmith's Avatar
looking at photo's (google images) it looks like there is a small spray rail on the aft third of the hull just above the waterline..
Sep 03, 2019, 11:45 AM
It's quite clear in the first pic on this link, which has some useful shots of the boat anyway.
https://www.yachtingmagazine.com/cla...cht-aphrodite/
Sep 03, 2019, 12:15 PM
Bob Gaito's Avatar
Ha! that picture is a nice find, Twobadboats,... there actually are two spray rails one about 1/3 back from the stem and a aft spray/ rub rail on the aft quarter(as stated by tghsmith)-Mikey, that will cure your water problem -true to 1:1 form!
Discussion So I'm going to be in San Francisco in two days..... Dave Campbell Life, The Universe, and Politics 66 Sep 07, 2017 10:00 PM
Discussion Please help. I need to get flying. I'm so close MrWings Electric Plane Talk 5 Jan 01, 2017 08:04 PM
Discussion I'm going to build an Alula. SSgt Baloo Hand Launch 54 Aug 17, 2013 04:50 PM
Discussion So I'm going to buy an Easy Star but.... wedge98 Beginner Training Area (Aircraft-Electric) 7 Sep 17, 2006 09:14 PM
Discussion So I'm going to build a USOM tommyeflight89 Sailboats 1 May 16, 2006 09:28 PM
