This thread is privately moderated by Ssayer, who may elect to delete unwanted replies.
Feb 12, 2019, 01:55 PM
Oldie, not Moldie
Ssayer's Avatar
3D Printed Micro Quad Racing Gates
Name: Floor Stand.jpg
Description: Name: Hung From Ceiling.jpg
Description: Name: Hung on Wall.jpg
Description:
https://www.thingiverse.com/thing:3423366
Unlike my first design, this time I wanted gates that were totally 3D Printed (because, you know, 3D Printer!). The only items needed that aren't 3D Printed are 1/4"x1/4"x1/4" Neodymium Magnets which cost about 20 cents each on ebay (and I'm sure multiple other venues). The magnet is a press fit, but obviously can be glued in as well. The reason for the magnet is that most open doorways (at least around here) have a metal corner around the perimeter (even though you can't see it). Also, the magnets stick to drop ceilings. Who knows what else you might find to stick them to like appliances, etc.
The gate itself is 300mmx300mmx7mm, which easily fits on my CR-10s 3D printer. If you're going to resize anything, keep in mind the 7mm thickness on the gate as it relates to the hangers and stand.
I included a few different lengths of stands and hangers, but everything is press fit (not everything is in the pictures). Easy to take apart, easy to store!
I'd recommend PLA Plus or better (like PETG) *I did mine with PLA Plus*, just because PLA can tend to be a little more brittle. I'm presuming that, like me, you won't always make it through the gate!
Feb 13, 2019, 06:31 PM
Oldie, not Moldie
Ssayer's Avatar
I uploaded a door hanger for the gate here:
https://www.thingiverse.com/thing:3426416
Name: Door Hanger.jpg
Description:
The gate is a press fit into the hanger and you're good to go. I made it for a door thickness of 1-5/16" (approx 34.5mm) to 1-3/4" (approx 45mm) as they were the narrowest and the thickest doors I have here.
Feb 14, 2019, 03:30 PM
Oldie, not Moldie
Ssayer's Avatar
Name: Trim Gate Side.jpg
Description: Name: Trim Gate Top.jpg
Description: Name: Trim Hooks.jpg
Description:
This is a door trim hanger for my Quad Racing Gate ( https://www.thingiverse.com/thing:3423366 ). The gate is a press fit into the hanger and you're good to go. I made it for a door trim thickness of 2-3/16" (approx 56.4mm) to 2-5/8" (approx 67mm) as they were the narrowest and the thickest door trims I have here. It needs a 3mm bolt that you self tap (by screwing it through the hole). In use, you only want to hand tighten the bolt to simply make the hanger snug on the door trim. I suggest two hangers for a gate.
You can find this piece here:
https://www.thingiverse.com/thing:3427563
Feb 15, 2019, 02:37 PM
Oldie, not Moldie
Ssayer's Avatar
Here's an Open Door Hanger for the gate. It could be mounted to a side of a set of shelves or other things as well...
Name: Hanger Open Door 2.jpg
Description: Name: Hanger Open Door.jpg
Description:
https://www.thingiverse.com/thing:3430367
I keep making add-ons, heck there is another one printing as I post this one.
Feb 15, 2019, 06:24 PM
Oldie, not Moldie
Ssayer's Avatar
Name: Gate Joiner A.jpg
Description: Name: Gate Joiner B.jpg
Description: Name: Gate Joiner C.jpg
Description:
This is a Gate Joiner for my Quad Racing Gate ( https://www.thingiverse.com/thing:3423366 ). Join 2 or more gates and play "Climb The Ladder" or simply use the different gate heights to vary your flying course. I've included 2 different lengths, and of course you're going to want to use 2 of either length to join your gates.
This piece can be found here:
https://www.thingiverse.com/thing:3430761
Feb 16, 2019, 04:23 PM
Oldie, not Moldie
Ssayer's Avatar
Name: Gate Flags.jpg
Description:
Thought of this because of the flags that I made for my Disc Golf course. I made each "flag" with 3 pieces. The holder, the background, and the number (or arrow). That way the number can be orientated to whatever works best for that particular gate and/or the arrow can be orientated to whatever it takes to point to the next gate. Plus it gives a greater choice for colors. (Obviously having all the flags on the gate in the pic is just for reference...)
The flags are here:
https://www.thingiverse.com/thing:3432677
Feb 18, 2019, 09:37 AM
Oldie, not Moldie
Ssayer's Avatar
Name: Magnetic Single Corner.jpg
Description:
I found an area that was metal, but didn't have enough surface area for two mounts. So I designed a piece that uses four magnets and only requires one hanger to hold the gate.
It can be found here:
https://www.thingiverse.com/thing:3436318
Feb 19, 2019, 09:12 PM
Oldie, not Moldie
Ssayer's Avatar
Name: Gate Size with 65mm Quad.jpg
Description: Name: Gate Size Comparison.jpg
Description:
Added a smaller gate. Just trying to keep the indoor flying interesting.
First picture is how it looks verses a 65mm quad.
Second picture is how it looks verses my larger quad racing gate.
You can find it here:
https://www.thingiverse.com/thing:3439807
Build Log DIY 2 indoor FPV LED racing gates for micro quads Haku Micro Multirotor Drones 2 Nov 27, 2017 04:11 PM
Cool Lets design an open source 3D printed micro Outrigger Race boat Jwmflying14 Micro and Sub-Micro Boats 75 Feb 16, 2016 04:22 PM
New Product SL250 Racing Quad - 3D printed 3dds FPV Racing 4 Jun 27, 2015 06:58 PM
