Mar 25, 2019, 12:49 PM
AMA# SIMAGES
simages's Avatar
Something was off......
The right LG is 8mm lower than the left.
Once corrected, everything lined up fairly well.
PA's flight weight is approx 33.7oz / 955g
This plane weighs in at 35.0oz / 992g - 35.5oz / 1006g (with Wheel Pants)
PA's CG range is 93 - 100mm / my CG is right at 95 - 98mm
Last edited by simages; Mar 25, 2019 at 05:54 PM. Reason: Anal Retentive Correction......
Mar 26, 2019, 04:30 PM
AMA# SIMAGES
simages's Avatar
Final Tweaks Done.....
Ready for Maiden and it will probably fly itself........
Latest blog entry: For Sale
Mar 26, 2019, 04:33 PM
AMA# SIMAGES
simages's Avatar
However; on second thought....
Although the V1 doesn't have the slots, I think I'll cut them in and add the Vortex Generators.
Mar 27, 2019, 07:47 AM
Hi all, I picked up one of these the other day for a good price complete with PA power system but the servos are Emax Es08 MA 11 12gram. The specs look good but wondered if anyone has any thoughts on these in this plane or their suitability.
Many thanks.
Mar 27, 2019, 11:51 AM
AMA# SIMAGES
simages's Avatar
Bummer....
Two cracks appeared on the canopy covering.......
UGH, but I can fix this.....
That's what the scrap decal sheets are for......
Mar 27, 2019, 01:08 PM
AMA# SIMAGES
simages's Avatar
Many thanks.
What color is the Extra 260?
I'm assuming the ones in your plane are Analog if so; it really depends on your flying style and needs during the flights like, precision, aerobatics, ability to hold the planes position and for many flight times are very important.... That being said; I personally prefer digital servos on control surfaces over analog especially in a 3D model and I know it's not always about the price. They seem like decent servos for the price and look like they've been around a while.
However; I've never owned these Emax servos so, maybe someone that has might chime in, but it might be better to post the question "directly" in the 3D Forum where thread is. https://www.rcgroups.com/3d-flying-188/
Hope this helps
Mar 27, 2019, 02:41 PM
Hi Simages,
Thanks for your thoughts. I have a 60" model with Hitec 7245 digital servos and think they are worth the extra cost but as this is more of a budget buy I am tempted to try it with the emax servos as long as they are up to the job. Spec wise they seem ok and they have metal gears, it's just I am unfamiliar with them. I think it's a few years old (although looks as new)It's a green one. Will try your link, thanks.
Mar 27, 2019, 02:51 PM
AMA# SIMAGES
simages's Avatar
Hi Simages,
Certainly, I'd agree and try them and as a new used model you'll probably get a better idea as you go through the maiden preflight setup. Also; the maiden will give you a better idea, who knows they might be just fine and maybe upgrade them later "if needed".
Mar 27, 2019, 05:25 PM
I was looking at your canopy and wondered why you showed picture 3 and 4? Then I realised it was the carbon underneath and not the same decals that are on the canopy of my Extra! I have had success with canopy glues and a piece of thin flexible plastic (old packaging) glued on the inside to reinforce. For picture 1 a bit of filler ( plastic airfix kit type for example) then spray BUT my preferred method is glue/ thin plastic to prevent further cracking followed by, as you say, decal cover up. I have had success printing images/ patterns off the computer to the right size to cover cracks etc. and then using clear tape to seal the outside. canopy glue adheres into place. You don't see it when you are prop hanging in front of you anyway!
Mar 27, 2019, 05:27 PM
Ah sorry, just realised. Those are the decals! Nice job!
Mar 27, 2019, 07:59 PM
AMA# SIMAGES
simages's Avatar
Yup...... that's what the scrap decal sheets are good for...... it was easier to seal the cracks and cover with decals because in that location it's yellow paint over the smoked canopy.....
Build Log Precision Aerobatics 48'' Extra 260 Build Thread! edge5foamy 3D Flying 6000 May 06, 2019 10:31 PM
Discussion Nitro Models Extra 260 50 - 53.5" 3D Aerobatic RC4x4 Glow to Electric Conversions 67 Feb 02, 2009 11:36 PM
Discussion 3DHS 47" Extra 300 SHP or Precision Aerobatics 48" Extra 260 myp 3D Flying 6 Sep 12, 2008 09:46 PM
