Feb 11, 2019, 08:58 PM
AMA# SIMAGES
simages's Avatar
Build Log
Precision Aerobatics Extra 260 - V1 Old production run
Waiting for delivery - PA is putting together the Yellow and Black Scheme, but they have to build the tail and Shuan has to complete the kit Quality Control before Adad can ship it. It will be worth the wait....Started on my RCG Blog
In the meantime I have a complete Ultimate AMR 40 kit arriving Monday.
Mar 12, 2019, 04:19 PM
AMA# SIMAGES
simages's Avatar
PA Rocks!!!
Got my V1 260 Extra today!
Latest blog entry: For Sale
Mar 12, 2019, 08:57 PM
AMA# SIMAGES
simages's Avatar
Time to Start......
Just finished my Mustang Strega project just in time and cleared the bench for the Extra!
Mar 12, 2019, 09:27 PM
The Extra looks good, I always wanted to get one as they are a true 3S 2200 plane. Enjoy the build.
Mar 12, 2019, 09:48 PM
AMA# SIMAGES
simages's Avatar
Its my 2nd PA, but 1st Extra. I really liked the idea of another 3s because my 3rd PA is the Ultimate AMR...... and I ordered a 4x Pack PA V4 Lipo 2200mAh 11.1V 25-50c with this order.
Mar 15, 2019, 02:39 PM
AMA# SIMAGES
simages's Avatar
Control Horn installs.....
I know this is a PA V1 260 which has been around for sometime now however; it's my 1st eXtra! Because of the black covering I had a H*** of a time finding the horn slots especially on the Elevator. I know I was not the only one.... as I searched and came across a few builds, comments and pictures.
Well I finally got to it and pulled through, but too often I'm a bit over meticulous or too careful..... ugh
Mar 15, 2019, 02:44 PM
AMA# SIMAGES
simages's Avatar
Motor mount reinforcement....
Straight forward and easy enough, now wait the 24 hrs. Also; went over inside of fuselage joints with diluted epoxy.
Mar 15, 2019, 03:10 PM
AMA# SIMAGES
simages's Avatar
Stabilizer Integrity
Well, not so good, guess I have a bit of filing to do......
Mar 15, 2019, 04:05 PM
AMA# SIMAGES
simages's Avatar
That will work.....
Much better....
Didn't take too much to fix, time to epoxy.....
Mar 15, 2019, 04:49 PM
AMA# SIMAGES
simages's Avatar
Tail Feathers...
Centered, Straight and Parallel.....
Epoxy to set overnight, great day goofing off!
Mar 22, 2019, 12:28 PM
AMA# SIMAGES
simages's Avatar
Ailerons, Elevator and Motor Box
Completed the Aileron and Elevator Servo installs as well as the linkage.
The extra balsa block for the elevator servo screws came loose even with pilot holes drilled. No problem, glued them back, re-drilled and are solid.
Motor Box lined up and fit perfectly as well as the pins which fit nice and snug!
I waited to install the tail wheel until now...
Mar 22, 2019, 08:14 PM
AMA# SIMAGES
simages's Avatar
Close to finishing
All that's lacking are pull-pull cables, cowl, prop/spinner, wheel pants and tweaking the flight mode control throws...
Last edited by simages; Mar 22, 2019 at 08:15 PM. Reason: Anal Retentive Correction.....
Mar 23, 2019, 01:56 PM
AMA# SIMAGES
simages's Avatar
Rudder control
The pull-pull cables are initially done, but need to tighten and fine tune at the servo arms.
Mar 23, 2019, 04:04 PM
AMA# SIMAGES
simages's Avatar
Cowl done
Easiest thing yet......
Mar 25, 2019, 12:44 PM
AMA# SIMAGES
simages's Avatar
Finishing up.....
I'd rather take my time with my builds.....
Added skid pad on battery tray, loving the PA 2200 V4 3s LiPo
Motor, Prop 13x5 and spinner done.....
Something's off sitting on the table....
Build Log Precision Aerobatics 48'' Extra 260 Build Thread! edge5foamy 3D Flying 6000 May 06, 2019 10:31 PM
Discussion Nitro Models Extra 260 50 - 53.5" 3D Aerobatic RC4x4 Glow to Electric Conversions 67 Feb 02, 2009 11:36 PM
Discussion 3DHS 47" Extra 300 SHP or Precision Aerobatics 48" Extra 260 myp 3D Flying 6 Sep 12, 2008 09:46 PM
