This thread is privately moderated by stsguy, who may elect to delete unwanted replies.
Feb 11, 2019, 02:07 AM
Trader Rating: 16
Where o where has my America g
stsguy's Avatar
$475.00 USD
Buyer pays shipping
For Sale
Cmp mosquito arf with air retracts
CMP Mosquito Twin Engine 73'' ARF with Air-Retracts and 2 sets of wings
CMP
DeHavilland Mosquito
25~32 - 73" Nitro Gas Radio R/C Twin Engine
Scale Warbird
ALSO CENTRY JET RETRACTS
37399 CMP/Giant Scale Mosquito
SHIPPING INFO AT BOTTOM OF THIS PAGE
BONUS!
With most large scale airplanes wing dipping on landing is common. Crosswind landings will at times cost you a BIG scrape on your wing tip or even more severe damage.
NO WORRIES
This kit has 2 sets of outer wing sections that are
included for free.
SKU: 37399 Category: Centurion (10 to 15 Pound)
Over $ 300.00 value
May consider selling with no retracts
ASK ABOUT LAYAWAY PLAN
Description
Centurion upper mechanism with dual 3/8″ diameter oleo struts. Axles installed. All rivets have been replaced with bolts. In addition, Centurion Bullet Proof inner struts come with a lifetime warranty. We are the only manufacturer who can make this claim. Why? Quality. In addition, all standard and Deluxe 4 Way valves come with a lifetime warranty. No one else makes this offer!
Deluxe 4 Way Valve for realistic air operations which provide the modeler infinite speed adjustments. All air standard and Deluxe 4 Way valves come with a lifetime warranty.
Below is the info we obtained online about this kit so you have info at your fingertips. This kit is a 100% virgin-SEALED kit. Wing bags, hardware bags etc have never been opened, unwrapped etc. So the description could have slight differences.
We, As always stand behind all our items so our customers can make a purchase knowing there is NO RISK INVOLVED!
The 73" Mosquito ARF is a great scale airplane for anyone who likes scale flying. The kit includes a fiberglass fuselage, center section, and cowling done in matching paint. The wings are sheeted foam, covered with solartex, painted to match. All control surfaces have beveled leading edges and the control horn mounts are preinstalled. The kit includes full-color decals.
The kit box is large, with all the major parts well packed in a light foam wrap and clear plastic bags. Slots in the interior cardboard held all items tightly in place, producing a sample of this product for review that will produce no damage from shipping. Included with the kit are 8-ounce fuel tanks, engine mounts, wheels, hardware, pushrods, clear plastic canopy and nose cone, decal sheet, one-piece fiberglass cowls, and fixed wire landing gear. You will need to purchase some building supplies, engines, spinners, servo extensions, and a radio. Mechanical retracts are an interesting option to consider. The quality of the materials is excellent with a one-piece fiberglass fuselage/fin straight and true.
Details and Recommendations:
Type: Semiscale ARF
Pilot Skill Level: Intermediate
Wingspan: 73 inches
Wing area: 1,286.5 square inches
Length: 52.5 inches
Weight: 11-11.5 pounds
Wing loading: 20.6 ounces per square inch
Engine: .25-.32 (two-stroke) or .26-.30 (four-stroke)
Radio: Five- to a six-channel transmitter, seven to nine servos (rudder, elevator, flaps, one for each aileron, one for each throttle, one for each optional retract)
Construction: Molded fiberglass fuselage, tail sections, wing center-section, and engine nacelles with light-plywood support, balsa-and-plywood wing panels and sections
Covering/finish: Three-color flat-finished camouflage paint over fiberglass, film covered wings and tail
Options: Retractable landing gear (Not Included)
Construction: Model assembly begins with attaching the ailerons to the wings using cloth-style hinges provided in the kit. The engine nacelle splits the flaps on each wing panel, which are connected with a U-shaped joiner wire. The flaps are attached after the wing sections are joined, to make their alignment easier to match.
The wing is composed of a center-section and two outer panels. The outer panels and control surfaces are built-up wooden structures, and the center-section is a fiberglass shell with a plywood skeleton.
Two aluminum tubes—measuring 87/16 inches in length and 3/4 inch in diameter—installed with epoxy are used as spars to permanently join the outer panels to the center-section with a slight amount of dihedral.
The aileron servos are installed in the outer panels before the wing is joined.
Four plywood formers give interior support to the fuselage’s one-piece fiberglass mold; the exterior seam joining the top and bottom is intelligently hidden with a change in paint color. The wing mates nicely with the fuselage’s saddle area using a notch and groove that ensures alignment. Three hefty metal screws are used to hold the wing in place.
The elevator halves are an airfoil-shaped, wood-frame construction. An aluminum tube that measures 615/16 inches in length and 3/8 inch in diameter joins the fiberglass stabilizer halves. The aluminum tube passes through a hole that must be cut through the sides of the molded fuselage. Each elevator half is connected to the ends of a Y-shaped pushrod.
Similar to the elevator halves, the rudder has an airfoil-shaped wood frame.
*RETRACT NOTE*
The retract bays are built into the wing from the factory, so the retracts will drop right in.
Engine Installation: Mounting the engine is fairly simple. Two-piece engine mounts (provided in the kit) are used to hold each O.S. .32 SX. The power plants are side-mounted so that the stock muffler vents to the lower side of the engine nacelles. Use a Dremel Moto-Tool to carefully carved away areas of each cowl so they could fit over the engine/muffler and give access to the fuel filler, carburetor port, and needle valve.
ELEC CONVERSION has been done and can be found online for step by step HOW-TOS
Mosquito ARF is covered with Solartex that has been professionally spray-painted with flat military colors: gray/green camouflage on the top and all light gray on the bottom.
The finish job is exceptional; all painted surfaces matched perfectly. Panel lines are embedded on all fiberglass parts. The quality and quantity of included decals are excellent. They are made from a stick-on material and have a flat finish to match the paint.
SHIPPING:
We Pack Well
(double boxed)
We Ship Fast
We Always
Insure Your Investment
(We DO NOT Mark-Up Shipping Fees
If A Quote Seems High Ask Us To Check For Possible Mistakes)
Remember all shipping rates were just increased
This is a HUGE BOX we will give you choices to get the BEST price to ship. We will work with you to save you money. We NEVER profit on shipping. Local Pick up is OK and we may even look to ship via BUS Ask for details.
Box size
54x22x14
22 pounds
WILL SHI{P VIA BUS ALSO
Feb 11, 2019, 05:14 AM
Trader Rating: 66
AMA 504253 Born in the USA
Yellowspider's Avatar
do you sell parts to this plane? I bought one a while back with no return, yep got screwed. It came with to left nacelles. So I need a right one. Or could be I need a left I forget its been so long.
Dave
Feb 11, 2019, 04:37 PM
Trader Rating: 16
stsguy's Avatar
sorry
Dave
I do not . Nacelle is easy enuff to make shape foam glass over sand sand sand lol I wish I could help sir
Sold CMP Zero 120 ARF with retracts 1ruffdog Aircraft - Fuel - Airplanes (FS/W) 1 May 13, 2018 04:52 PM
Sold CMP T-45 ARF 90mm EDF New in box with Metal Gear and retracts jedijingle Aircraft - Electric - Jets (FS/W) 1 Dec 08, 2017 08:50 PM
Sold CMP Spitfire 50 - 54" Nitro Gas Radio Control Warbird Plane w/ Scale Retracts ARF CMP jricchio Aircraft - Fuel - Airplanes (FS/W) 4 Oct 12, 2016 08:42 PM
Sold CMP Mosquito ARF - 40 Size - PRICE REDUCED GoFlyNow Aircraft - Fuel - Airplanes (FS/W) 2 Jun 26, 2016 08:25 AM
Wanted cmp bf109 air retracts with struts shader Aircraft - General - Miscellaneous (FS/W) 1 Dec 06, 2014 12:41 AM
