This thread is privately moderated by lepiere, who may elect to delete unwanted replies.
Feb 10, 2019, 05:59 AM
DRONELANDER Boss
lepiere's Avatar
Mini-Review
Holybro KOPIS 2 - My First Ready-To-Fly FPV Racing Drone is a MONSTER
Holybro KOPIS 2 - My First Ready-To-Fly FPV Racing Drone is a MONSTER (10 min 21 sec)
The Holybro Kopis 2 is a ready-to-fly fpv racing drone and is also my first racing drone. After 20 hours on Liftoff FPV drone simulator, I'm able to take off, land and do some trick always in acro mode.
Main Kopis 2 characteristic is the frame: inside arms and bottom plate, there is a white material called ROHACELL: https://goo.gl/4KMthn
Inside the frame, lot of technology with Kakute F7 FC, vtx Atlatl HV V2 800MW, Tekko32 4 in 1 35A (compatibile Dshot1200) and brushless motors T.Motor F40 PRO2 2400KV: you can buy it from here: http://shrsl.com/1fnpw
LIFTOFF FPV SIMULATOR: https://goo.gl/NgzBcA
RADIO TARANIS QX7: http://shrsl.com/1fnpo
Features:
-5mm full 3k carbon fiber twill.
-Counter-sunk screws on base for great appearance and protection of battery against damage.
-KakuteF7 flight controller with soft-mounted gyro for mechanical filtering of vibration. Means you can disable more software filters for best flight handling.
-Improved soft-mounting foam for KakuteF7 gives optimal balance of stiffness and damping for even better gyro performance than before!
-Betaflight OSD included. Monitor voltage and battery capacity in your FPV goggles. Change PIDs and Rates using your transmitter sticks.
-Atlatl HV V2 video transmitter:
5.8 GHz
Standard 40-channel set. However 5645 MHz and 5925 MHz 5945 MHz are illegal in many areas, so they are not supported. If you select one of these channels, it will simply fail to work.
Output Power: 0.5 mW (pit mode), 25 mW, 200 mW, 500 mW, 800 mW
MMCX antenna connector for easy, secure connection. Won’t break or come loose like the IPEX connector used on other vTX.
Control the vTX channel and transmit power from the OSD using your transmitter sticks or from your Transmitter. No more picking up the quad to change vTX settings!
-Buzzer included.
-RunCam Swift Micro FPV camera
-Adjustable camera uptilt from 0 degrees to 90 degrees.
-Serial receiver supported (SBUS, iBUS, Spektrum). Legacy PPM and PWM receivers not supported
Discussion Holybro Kopis 2 FPV Racing RC Drone PNP BNF w/ Kakute F7 OSD Atlatl HV V2 800MW 35A D scousethief Banggood.com 5 Sep 22, 2018 11:15 AM
News Holybro Kopis 1 Racing Drone Jason Cole FPV Racing 8 Dec 13, 2017 06:30 PM
Discussion Holybro Kopis 1 FPV Racing Drone 5mm Arm w/ F4 5.8G 40CH Dshot1200 RunCam Swift BobFromMars Banggood.com 0 Aug 29, 2017 06:47 AM
New Product Holybro Kopis 1 FPV Racing Drone smg24 Banggood.com 0 Aug 29, 2017 06:46 AM
Discussion My first racing drone (Holybro shuriken x1) Jonny3773 Mini Multirotor Drones 3 Feb 22, 2017 09:27 AM
