This thread is privately moderated by TinkleWid, who may elect to delete unwanted replies.
Feb 08, 2019, 05:45 AM
TinkleWid's Avatar
Mini-HowTo
Caddx Turtle V2 Settings 🐢 Colour Graded 🔥🔥 Best Crystal Clear HD Image 🎬 Adobe
Caddx Turtle V2 HD - Colour Grading works very well on the raw output file using Adobe Premier Pro with the following settings:
Exposure - 0.5
Contrast + 40%
Highlights - 20%
Shadows -+ 30%
Whites - 25%
Blacks - 10%
Saturation 30%
Caddx Turtle V2 Settings 🐢 Colour Graded 🔥🔥 Best Crystal Clear HD Image 🎬 Adobe Premier Pro Edit 🎬 (1 min 20 sec)
Just had time for a quick fly in the sun for the first time in weeks (although still with frozen fingers) I managed to get a short circuit on my flight controller in the wet grass 😞😞😞😞😞😞
I made the shadows much darker than in my previous videos by reducing the overall brightness. I may have overdone it so let me know if I did
Caddx Turtle v2 🐢 [4:3] FVP Flow Progression 🐢 Getting some Fresh Air (3 min 41 sec)
Equipment Used:
Flying the Kwad Karl (Bando Racer 3) BR3 Frame with Caddx Turtle v2
XJB 145 build and motors https://www.banggood.com/HGLRC-Flame...18277502201801
Caddx Turtle v2 https://www.banggood.com/Caddx-Turtl...18277502201801
XM+ https://www.banggood.com/Frsky-XM-Micro-D16-SBUS-Full-
Range-Receiver-Up-to-16CH-p-1110020.html?p=YE151218277502201801
VRD2 Pro Goggle rather than the TopSKy Prime 1S https://www.banggood.com/Eachine-VR-...tlinkid=124518
Jumper T8SG https://www.banggood.com/Jumper-T8SG...d=124521124520
Gemfan 3052 https://www.banggood.com/2-Pairs-Gem...18277502201801
Adobe Premier Pro for Caddx V2 post-production
I still think this footage is better than the output of the Runcam Split Mini 2 . It's not quite as good as as a Go Pro but that won't stop me being an aerial acrobrat; what fpv hd camara do you think is best?
Best firmware versions dated 7th September 2018
Caddx Turtle Settings: 1080p 60FPS
Wide FoV
7 saturation
1 Sharpness
5 Contrast
5 Brightness
EV -0.3
WDR on
Ensure you lower the sharpness to 0 or 1 unless using another lens
Caddx Turtle V2 is NOT ALWAYS SHIPPED WITH THE LATEST FIRMWARE 😱😱 The latest caddx turtle v2 firmware is AMAZING 😱😱
(Note: How to repair a bricked Caddx Turtle with black screen)
How to repair a bricked Caddx Turtle from a firmware update
http://www.multirotorguide.com/guide...rmware-update/
September Firmware - works with v2 and soon to be tested with v1 board https://www.rcgroups.com/forums/show...5&d=1541439082
Note: Just seen the new Foxeer Mix HD Camera Footage
Foxeer Mix // 1st Flight Footage HD+DVR (3 min 22 sec)
[It looks a little over sharpened like the Caddx Turtle V1and the FPV feed looks washed out with no contrast but it will be interesting to see if this can be fixed]. I wonder if thre Foxeer Mix camera will end up being the same as the Caddx Turtle. It will be good to see a Foxeer Mix vs Caddx Turtle v2 video.
The Competition-
http://foxeer.com/Foxeer-Mix-1080p-6...V-Camera-g-213
Foxeer Mix HD Camera UK
https://www.unmannedtechshop.co.uk/p...hd-fpv-camera/
Review Foxeer Mix vs Predator V3 (Discounted)
https://www.banggood.com/Foxeer-Pred...tlinkid=127401
Caddx Turtle v3 - awaiting confirmation of update. Looks like just a new glass lens at the moment. Also hearing about a Caddx Ratal Camara?
Feb 08, 2019, 01:14 PM
LemonC's Avatar
your 3in footage looks pretty nice! i havent flown my 3in in a while, my dvr was complete garbage compared to this caddx setup.
im curious what some long, low to ground footage would look like (grass shot)
Feb 08, 2019, 04:41 PM
TinkleWid's Avatar
Thanks - I have only flown 2-3 times in the last couple of months as the weather has been awful. My last trip out lasted for 3 lipos!
The video below starts off low to the ground and looks fantastic. Make sure you're firmware has been updated as previous firmware suffered from a low bitrate https://youtu.be/27rfD15TPQo
New Product Caddx Turtle V2 800TVL 1.8mm 1080p 60fps NTSC/PAL Switchable Mini HD FPV Camera w/ DV smg24 Banggood.com 2 Jul 02, 2019 04:38 PM
New Product Makerfire Armor 85mm FPV Racing Drone F3 FC OSD Caddx Turtle V2 HD Cam 5.8G 40CH 25/1 scousethief Banggood.com 2 Jan 15, 2019 11:38 AM
Discussion Caddx Turtles FOV 145 Degree Super WDR Mini FPV Camera 1080P 60fps DVR - Micro HD! BobFromMars Banggood.com 0 Jul 05, 2018 09:05 AM
