Oct 04, 2019, 03:42 PM
Originally Posted by Beaver_XT;42876471.... Or Surpass Rocket. [url
https://www.aliexpress.com/item/33052771236.html[/url]
Would this ESC be good for this motor? https://tiny.cc/7bvydz
Oct 04, 2019, 05:03 PM
Low budget fun
Beaver_XT's Avatar
I've tried it. It has a lot of cogging (stutter) at low rev so I don't recommend using it with Surpass Rocket. The Mini-Q ESC (made by ZTW) is better. https://hobbyking.com/en_us/15a-brus...y-tz4-awd.html
However XC-10A works really well with older Surpass 1410 6000KV. You probably have seen it in my budget electronics for DRZ video.
Oct 04, 2019, 05:29 PM
Brake Weight's Avatar
Too big???
https://rover.ebay.com/rover/0/0/0?m...2F201370331296
Oct 05, 2019, 12:44 AM
Low budget fun
Beaver_XT's Avatar
Originally Posted by Brake Weight
Too small.
Oct 07, 2019, 06:41 AM
Porcorosso's Avatar
Motor in hobbyking is too powerful but you can try. https://hobbyking.com/en_us/6000kv-b...y-tz4-awd.html
Highly recommended 3500KV from Atomic. http://www.miracle-mart.com/store/in...ducts_id=14065
Or Surpass Rocket. https://www.aliexpress.com/item/33052771236.html
Here's the lipo. This one fits perfectly. I have GiantPower in the same size. https://hobbyking.com/en_us/turnigy-...lipo-pack.html
Thank you Beaver. Does the Atomic motor comes with the right connector for the ESC that comes with the DRZ kit ?
Regarding the Lipo, can the Atomic ESC connect with the standard balancing connector of this Lipo ?
Oct 07, 2019, 07:35 AM
buying an atomic drz?
Too small.
That’s what I use in my Losi 1/24 Rally.
Oct 07, 2019, 11:27 AM
Low budget fun
Beaver_XT's Avatar
Yes, the Atomic motor will work with its ESC plug.
And yes, the battery plug is via balance plug however the size is not standard balance plug, it's JST-PH 2.0mm 3 pin. So you'll have to make a converter.
Is that 1222 size? It looks pretty small though. The motor for DRZ is 130 brushless so either 1625 or 1410.
Anyway, if the shaft is 2mm, length no more than 26mm and mounting is by this standard then it will work.
https://www.scorpionsystem.com/files..._dimension.pdf
Oct 07, 2019, 02:00 PM
I think it may be longer than 26mm.
Oct 16, 2019, 11:21 AM
Hey Beaver, love your videos by the way
I just got my DRZ form rcmart last night,
The only thing im missing is a gyro, I saw your budget build drz but the gyro you used is really big for that scale,
Do ''mini or micro'' drift gyro exist ?
The only one I could find that was somewhat smaller is this one : https://www.aliexpress.com/item/3284...chweb201603_52
But even then, the reviews are really mixed…
Thanks for your advices!
Oct 17, 2019, 07:42 AM
Low budget fun
Beaver_XT's Avatar
There is another mini gyro you can use. I've been told it's better than the one from atomic too but I haven't tried it yet. https://www.ebay.com/itm/3944MINI-BK...K/254103498486
It's the same as hackslider mini.
https://www.ebay.com/itm/Yeah-Racing...g/132808365472
Discussion Atomic DRZ 98mm body ? Redrun Micro Cars 4 Nov 01, 2018 02:25 PM
Cool Have you ever seen an atom? Zaurak3 Life, The Universe, and Politics 30 Feb 16, 2018 09:55 AM
An Atomic Force in my Corona put a :) on my face! tdriedger Electric Heli Talk 10 Apr 29, 2003 07:50 PM
maintaining an Atomic Force motor JoeR Power Systems 5 Jun 19, 2002 10:10 PM
