This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Feb 05, 2019, 09:07 PM
old4570's Avatar
Elf dlg
Wow !
Been Ho humming over a Elf for a long time ..
HK has brought back the Raven 1500 and I nearly ( Nearly )
But for the same money , I could have the ELF .
There is a local retailer who advertises the ELF , so I shot off a email and he said he had stock .
So some $$ later and a insufferable drive to pick it up ..
( Insufferable Drive )
Oh my G ! Seriously , some Melbournites cant drive for "S" .
Who the heck does 47kmh in a 70kmh zone with no one in front of them ( well #$^%& do - the self inflicted ones )
The roads have simply become car parks and with an over abundance of idiots , the traffic crawls .
Sometimes for reasons I can not comprehend . To say it stresses me out is an understatement .
2019 = I really despise driving a car .. Every year it gets worse and every year I drive less ..
I bought fuel in November 2018 and I still have half a tank ..
( Back to the Elf )
Wow , this thing is trick / tech / flash / and I dare say not for Noobs !
Building instructions are some what lacking .. ( Non existent )
You are pretty much left to your own devices on this one .
Thankfully the ELF is more assembled now compared to when it came out .
Now you simply glue in the tail surfaces ( Simply ??? ) , pop in your servos / receiver and battery ...
Bolt on the wing and go fly ..
Ok , maybe not that easy !
Virtical fin ( tail surface ) Rudder -
There are no markings / guides / bla bla - measurements given for placement ..
So get out you pencil and set square , draw a glue line on the vertical fin ..
I kind of eyeballed it against a picture of a assembled ELF and drew in the line using the set square working of the carbon insert ( spar ) ..
Then put some Cyno in the tail boom and held the fin in place as straight as I could ...
Horizontal Fin ( elevator ) ..
You need to cut a slot for the insert that gives you a all moving elevator ..
You need a 16mm slot ..
Again with the set square and pencil start drawing straight lines and work out the middle of the elevator ..
I cut behind the carbon spar ( moves the Ele a fraction more forward ) ..
Then test fitted and once again cyno'd as best as possible keeping things straight and level ..
I cant say it's perfect , but its the best I can do with the old bush league effort ..
Eye balls ok ..
So that be where I am at right now , tail surfaces are glued ..
Next I have to do the rudder control horn ..
And then think about the servos ..
More tail talk + pictures
https://www.rcgroups.com/forums/show...9#post41104443
Discussion Repair Elf DLG wing Ffog Hand Launch 10 Mar 21, 2019 12:36 AM
Discussion New to DLG - need advice for setup for ELF Stokkis Hand Launch 18 Jan 22, 2019 01:32 AM
Build Log Scratch build 50" DLG Apogee- Elf look alike hog2soar Hand Launch 28 Jun 13, 2018 12:16 PM
Question Is the Elf the ultamate fun flyer DLG? rdwoebke Hand Launch 15 Jul 22, 2016 10:42 AM
Build Log New "T-Beam Boom" and balsa pod for my 50" Apogee/Elf DLG look alike hog2soar Hand Launch 7 Jan 15, 2016 01:34 PM
