Mar 06, 2019, 12:33 PM
right wing panel is underway
Clamps shims and magnets then hope for a straight wing. The table is inch and a half furniture grade birch with metal plate glued to the top. The bow in the middle is about the depth of three sheets of paper.
Mar 19, 2019, 07:45 PM
working at how to raise the spoilers with a small servo located at the spoiler. Some good weather has slowed down building.
Jerry
Apr 23, 2019, 08:39 PM
spinner size
What size spinner should would be right for this sailplane?
Apr 25, 2019, 09:49 PM
who has rabbit ears down
Captain Canardly's Avatar
From what i remember of Bob's bird, prolly about 40-50mm, but maybe a (Radian's) replacement would be OK
Apr 28, 2019, 09:14 PM
spinner size
Thanks, I'll cut some discs those sizes and see how it looks
May 11, 2019, 09:33 AM
Flying Low
cbarnes0061's Avatar
Just received one of these short kits myself. Will be following closely.
May 28, 2019, 05:16 PM
instalation of nose block
images are giving me trouble downloading. Rather large nose block . A lot of it will be sanded away
May 29, 2019, 02:30 AM
Looks like things are moving along quite well
May 29, 2019, 10:48 AM
Flying Low
what motor, prop, and esc combo do you plan to run as I want to make mine electric as well.
May 30, 2019, 05:30 PM
wing fairing
With good flying weather and Joe Nall building took a back seat. Today it is 93 in the shade at 6:15PM. The small window unit in my shop has not shut down all afternoon. Do I have to include the price of electricity in the cost of building this thing.
The rear tube support 1/4 inch spar was not cut in the ribs. If you are building this plane from a laser cut kit check ribs 1,2,3 and 4 for the upper and lower notches for the supporting spar for the rear tube.
May 30, 2019, 07:37 PM
motor and prop
Dualsky XM2838EG-14L motor
Aeronaut Cam 14"X8" prop
from Aloft hobbies
May 30, 2019, 07:40 PM
Esc
Most likely I will get the local hobby shop to pick out an appropriate esc. We have a knowledgeable individual running the shop in Cary.
Jun 03, 2019, 04:24 AM
polyhedral
What is the best way to brace the polyhedral joint. using welding wire as shown does not look good. Do sailplanes use this often?
Jun 15, 2019, 10:29 AM
note to Cbarnes
[quote=cbarnes0061;41836205]just received one of these short kits myself.
the notches for the rear spar were left off by the laser cutter.
Much easer to fix if you recognize this and cut the notches before gluing the bottom sheeting on
Discussion Durex V yellowbluebird Thermal Soaring 4 Feb 05, 2019 03:42 AM
Discussion Durex V yellowbluebird Sailplane Talk 4 Jan 30, 2019 01:35 PM
Discussion Durex V - First Stratch-Build / First Glider pappy35 Thermal Soaring 33 May 15, 2017 08:16 AM
Build Log Durex V trident58 Thermal Soaring 126 Dec 08, 2013 09:31 AM
Discussion Durex V Mirage1 Thermal Soaring 8 Mar 09, 2007 10:22 PM
