This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Feb 04, 2019, 07:34 PM
old4570's Avatar
Bushfire Morning 5 Feb 2019
Something is burning outside ..
A very nice hazy smokey eucalyptus morning ..
I took the 480mm DIY Rc glider out for round 2 .
Since I have had several HOT days to think about what it was doing I have
1) Moved the battery as far forward as possible
2) More down elevator
And it glides in a straight line now
So I walked to the park and tossed it on the hill ( )
The 480 had problems penetrating , for some strange reason that hill seems to push models down towards the ground ( Where is the lift ? )
Might be the trees that line the park ? ( Turbulence ? )
Anyhow , it does glide ..
When I got off the hill , I threw it some more at ground level and it performed rather well
????? Why so bad on the hill ?
At ground level it was really nice , but on the hill it just refused to move forward ..
Oh well ! it does glide ..
But at 480mm , I would call it a waste of time .. Don't think its a worth while project ..
I am trying to track down a 600mm version of these gliders ...
@ 600mm , such a RC conversion might be worth while ..
The 480 still tip stalls , and is very jittery in the turns .. I'd simply call it too small to be practical .
Ripit Rev 2. ?
The wing is done ..
Rudder is done
Servo is done
I actually killed the 4ch FS 2A Rx de soldering it , to re solder the servos ...
So I pulled out another Rx and soldered the pins on ..
This meant soldering plugs / connectors to the sub micro servos ..
This means there is not enough room in the nose cone ..
So I had to cut off some balsa that the Rx and battery attached to .
So now the Rx and battery are floating in the nose ( Not that happy Jan )
Need to install a control rod and then do a canopy stop ( so the canopy does not slide to far rearward )
Install the wing with CG as close as possible ..
Then go play ...
Contest 12th Annual San Felasco Hand Launch Glider Festival Feb 15-17 2019 David Forbes Hand Launch 225 Feb 27, 2019 07:26 PM
Fly-In ~~West Florida All Electric Fly-In Feb. 22nd-24th, 2019 Palmetto, FL ~~ AlanFlorida RC Flight Events 50 Feb 26, 2019 08:34 AM
Contest FSS #2 and #3 Feb 2 and Feb 3 2019, Christmas FL raed5 Sailplane Events 16 Feb 04, 2019 09:14 PM
Swap Meet 26th NNPRCC Swap Meet, Feb 16, 2019, Newport News VA Zfthomp RC Flight Events 0 Dec 16, 2018 07:55 PM
