Feb 04, 2019, 03:01 PM
Video
Exceed RC Rock Crawler RC Truck 1/16 Max Watt 4WD WaterProof Electronics
1/16 Max Watt Rock Crawler RC Trail Crawling (2 min 47 sec)
1/16 Exceed RC Max Watt Crawler Overview (1 min 26 sec)
Buy it here!
https://www.nitrorcx.com/51c900-maxw...awler-red.html
The 2.4Ghz RTR Exceed RC Max Watt was designed to be the succussor to our popular 1/16th Max Stone, it has all the great features of the original Max Stone with some new changes. The new Max Watt has a slightly lower center of gravity, and larger wheels and tires.
Previously the only way to build a competition capable rock crawler was to buy bits and pieces of several different kits here and there. This long and sometimes frustrating process could take as long as several months just to get the right parts together before you could even start the build. Now you can get a factory built rolling chassis, and able to hit the rocks with your competition ready in no time.
The Rock Crawler embodies good features from real rock crawlers. Multi-link suspension and axles provides all 4 wheels through A center-mounted 3-gear transmission, providing tremendous grip and torque at all times and overcome any obstacle that it may meet with.
Features:
Full ball bearing throughout whole vehicle
Multi-link suspension allows for smooth crawling
Four wheel driving provides tremendous grip for wheels
Anodized aluminum chassis
"Truck/Hammer/Wecker" style body
Alloy lower suspension link bars with captured ends
3-Gear center-mounted transmission
Solid axle mount provides protection for front/rear shaft
High precision ESC w/ reverse function
High precision 4 channel receiver
Designed from the get-go as a rock crawling machine that goes anywhere.
Super long shocks offer a wider range of articulation.
Advanced monster stocks design provides the best support.
The 2.4Ghz RTR Exceed RC MaxStone transmission was designed to place the weight of the motor as low as possible to maintain a low CG (Center of Gravity).
The 2.4Ghz RTR Exceed RC MadStone chassis is lightweight and stiff.
Unique Aluminum Alloy twin vertical plate chassis design.
Axle -Mounted steering servo.
High-torque 540 motor.
Advanced tire pattern provides best grip and balance.
High performance electronic speed controller.
Revolutionary multi-link crawler suspension design
Heavy duty special harden metal ring and pinion gears, axles and axle shafts
Advanced locked differentials four wheel drive design
High performance racing level 7.2v 1800mah ni-mh battery.
Waterproof Electronics
Length: 345mm
Width: 190mm
Height: 180mm
Wheelbase:235mm
Gear Ratio: 1:88
Servo: 2.5KG
Motor: RC370
ESC: 25A
Battery: Ni-MH 7.2V 1100mAh
Radio System: 2.4G
Weight:2.4KG
Package Include:
7.2V 1100mAh Ni-MH Rechargeable Battery
Wall Battery Charger
2.4Ghz Pistol Grip Radio Remote Controller Transmitter
Instruction Manual
Required to run
4x AA batteries
New Product JJRC Q40 1:12 2.4G 4WD Short-course Truck Rock Crawler Off Road Mad Man RC Car Merch Off-road Cars 0 Oct 14, 2017 02:20 AM
