Feb 04, 2019, 02:57 PM
Video
Exceed RC Trophy Truck RC Truck 1/16th Scale 2.4Ghz Max Rock 4WD WaterProof
1/16 Exceed RC Max Rock 4WD Trophy Truck in Action (2 min 10 sec)
Exceed RC Max Rock 1/16 Scale Rock Racer Trophy Truck (2 min 6 sec)
Buy them here!
https://www.nitrorcx.com/51c959-maxrock-16-sct-red.html
https://www.nitrorcx.com/51c959-maxr...-sct-blue.html
NitroRCX has entered the trophy truck market with the 1/16th Max Rock. Want to take on the Rock Racing series then the Exceed RC Max Rock is ready for you! Similar to it's larger 1/10 brother it deatures aunique chassis design of the Max Rock which gives you the realistic driving characteristics of a full sized trophy truck. It features a 4-link solid rear axle with independent front suspension for the true rock racing experience.
The radio features a pistol-grip design with 2 channel functionality, steering and throttle dual rates, steering and throttle exponential adjustments, servo reversing. The radio prevents frequency conflicts automatically and changes channels if there is any interference. You'll have professional-level control in one easy ready to run package. Propelled by a 380 sized high performance brushed motor. A two in one brushed electronic speed and receiver delivers the current efficiently through an included 7.2v 1100mah Ni-Mh battery and charger.
The Max Rock was designed to not only look good but to perform, large off-road tires are aggressive to grip the toughest of terrain. Dirt, sand, snow, mud, rain, this truck will smash through it all.
Length: 300mm
Width: 178mm
Height: 128mm
Wheelbase:206mm
Wheel Track:156mm
Ground Clearance:30mm
Servo: 17G
Motor: RC380
ESC: 2 in 1 ESC Built in Receiver
Battery: Ni-MH 7.2V 1100mAh
Radio System: 2.4G
Weight:0.74KG
Package Include:
7.2V 1100mAh Ni-MH Rechargeable Battery
Wall Battery Charger
2.4Ghz Pistol Grip Radio Remote Controller Transmitter
Instruction Manual
Required to run
4x AA batteries
