Mar 06, 2019, 02:16 AM
prondel's Avatar
Hi Viktor,
Yes it is. I loaded it on dropbox because it was too difficult to find it on manufacturer website.
Pierre
Mar 06, 2019, 03:08 AM
ViktorF's Avatar
APK installed, but I'm not sure how to do the calibration. So far I've found and pushed "Acc calibration" at "Set" tab (left up corner) and values migrated to zero. I do rotate device in all axes, X and Z show angle from 0 to 180 degrees, Y show from 0 to 90 degrees. 90 degree on X and Y looks about right.
Upd
Switched back to Throwmeter App, values looks correct now.
If device require calibration before use, then article must be updated.
Or, calibration mode have to be included in Throwmeter App, as well as keeping the phone from sleeping.
Mar 06, 2019, 01:04 PM
prondel's Avatar
Hi Viktor,
Good to know the values seem ok now.
Yes there are several improvements to do for sure. I will update the doc on planet-soaring.
Now, don't forget this App costed you nothing ...
Pierre
Mar 06, 2019, 02:06 PM
simple test
I am interested in the system but I would like to know the real accuracy.
If somebody has this system could he/she do some small test.
1) Use an (old) " wing and place the sensor on it.
2) zero the system.
3) Then place a drill of a diameter of 1mm between flap and block (the red arrow) and see what the app is telling how many mm the flap moved(should be 1.0 mm)
4) repeat this with drill from 2 to 12 mm.
I am really curious about the outcome.
( I did this with a MMA sensor but was not happy about the result. Maybe the program was not good enough)
Jeroen
Mar 06, 2019, 02:58 PM
ViktorF's Avatar
Pierre,
I'm not blaming at all, it's just a feedback for possible improvement.
Mar 06, 2019, 03:26 PM
ViktorF's Avatar
Jeroen,
and how much MMA sensor was off? I wouldn't worry if it was a fraction of mm.
Mar 06, 2019, 03:42 PM
prondel's Avatar
Originally Posted by ViktorF
Pierre,
Hi Viktor,
No worries. I'm maintaining a list of improvement.
Pierre
Mar 06, 2019, 03:43 PM
prondel's Avatar
Originally Posted by vitas View Post
thanks for the project, works great. Is any plan to make the app open source? I would like to fix some issues: automatically reconnect device or keep connection by sleep. Also, would like to add support of two devices.
Hi Vitas,
Yannick started the migration of the source code to github.
I will let you know when it is available.
Pierre
Mar 06, 2019, 03:57 PM
Originally Posted by ViktorF View Post
Jeroen,
Pierre,
it was more then 1mm and even was getting more when the deflection was bigger.
for me 1mm is toomuch.
Jeroen
Mar 09, 2019, 12:14 PM
Originally Posted by prondel View Post
Hi Viktor,
Try to install the manufacturer App (link below to my dropbox) and do a full calibration first at startup (device on a flat surface):
https://www.dropbox.com/s/0p4ga2u31r...20IMU.apk?dl=0
Pierre
Hello Pierre,
first of all many thanks for your efforts!
I tried to calibrate the device with the APP you mentioned, but this APP wasn't able to connect to the device.
Interestingly your APP is working, even though sometimes the connection is lost.
Any ideas?
regards
Gerhard
Mar 10, 2019, 12:12 PM
ViktorF's Avatar
Today I've had chance to check measurements precision.
Not a real wing, but some scrap pieces, higned with a masking tape.
And need to say, precision is good enough, within 0,1mm.
Mar 10, 2019, 01:36 PM
mlachow's Avatar
Pierre,
Jeroen
You also have to look at how the program calculates deflection. Does it give you deflection in the Y axis or does it calculate the distance of the TE from zero TE position which is what the one mma program does. So your answer will always be greater than your shim.
Mma needs calibration. If you think 90 degree travel would report the width of the control surface, the program gives 1.41* .
I have a rotary table that I use for checking.
Mar 10, 2019, 03:45 PM
ViktorF
This is much better then I had with the MMA sensor!
mlachow:
I did the calibration (5 times).
X Y Z X Y Z
-4138 -4038 -4094 4078 4162 4032
-4140 -4032 -4094 4080 4170 4014
-4148 -4034 -4098 4084 4158 4018
-4142 -4034 -4092 4082 4158 4024
-4144 -4040 -4094 4078 4148 4016
( i measured the deflection on a horizontal wing)
I will stop here otherwise i am using Pierre thread.
gtz
Jeroen
Mar 11, 2019, 01:47 PM
Hello,
I was able to connect the device with the calibraton APP (button "BLE" has to be clicked).
But after trying to start the calibration by pressing the button "SET" the APP crashes and stops.
Has anybody of you made the same experience and found a solution.?
many thanks in advance!
Gerhard
Mar 11, 2019, 03:19 PM
ViktorF's Avatar
May be not enough free memory at the smartphone?
New Product GD-006 DIY EPP 548mm Wingspan DIY RC Airplane RTF Built-in Battery scousethief Banggood.com 2 Oct 15, 2018 06:00 AM
Discussion Bluetooth enabled MFU for RC cars and trucks available now on Kickstarter ao_to Electric Power Cars 0 Nov 21, 2015 01:41 AM
Build Log DIY bluetooth module for VBAR AndrewStick DIY Electronics 10 Feb 29, 2012 09:43 AM
