This thread is privately moderated by 1boho, who may elect to delete unwanted replies.
Feb 01, 2019, 07:52 PM
Designing Iscad
Hi,
I want to work on an Intelligent stator cage design here. we have had already many ideas but it means nothing if no one will try the work. So
I will.
Feb 01, 2019, 07:56 PM
Because I already have it at hand the easiest design to bring forth it a slotless ISCAD design. So we start with a core from a slot less in runner. And 1/8 soft copper tubing for the conductors.
Feb 14, 2019, 09:44 PM
Mar 06, 2019, 04:59 PM
Hi,
The ISCAD will be an inrunner with a 10 pole 41.40mm rotor. I will build the induction inrunner motor around this. Im sure something purposed designed may be better but all we want is to verify a motor in a size similar to what we run.. My Brother pressed me for an open slot design so Ill do it here open 18 or 14 slot stator. This will allow us to fully incorporate Novel IEEE methods of cooling and removing unwanted space harmonics. Through Ferro fluid coolant channels. Shifted winding schemes , drive options
Mar 08, 2019, 07:20 PM
And so we take a step back and go purely to an induction machine with rotor bars. This rotor isn't optimized but we don't want to skew the slots. We will use the proposed stator windings to deal with space harmonics. This looks raggedy but the rotor laminations have no welds or tabs holding them together. It is a pure cut stack and 10 poles. From that standpoint it is ideal. Ill have to ask Christian is it possible create a good stator to go around it. Build a hobby sized induction machine to see if we can and it will run. I also got an extra 8mm ground shaft out of this salvage from an antique brushed trolling motor . 18N10P hobby sized induction motor is the new quest
Mar 22, 2019, 04:51 PM
Description:
So we find a start to controlling ISCAD with a stepping program and hardware. A quad comparator. TI LM339 and the parallax 8x32 bit microprocessor. It doesn't have to be these pieces but this is what on hand. Ill set up a small circuits and see if we can step a sinus signal.
Open Source code.
''Demonstration of PWM version of NCO/PWM counter mode
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
VAR
long parameter
PUB go | x
cognew(@entry, @parameter)
repeat
repeat x from 0 to 90 'linearly advance parameter from 0 to 100
parameter := cos(x,90) << 16 + sin(x,90) 'a constant here locks to value x percent high
waitcnt(1_000_000 + cnt) 'wait a little while before next update
repeat x from 90 to 0 'linearly advance parameter from 0 to 100
PUB sin(degree, range) : s | c,z,angle
angle := (degree*91)~>2 ' *22.75
c := angle & $800
z := angle & $1000
if c
angle := -angle
angle |= $E000>>1
angle <<= 1
s := word[angle]
if z
s := -s
return (s*range)~>16 ' return sin = -range..+range
PUB cos(degree,range)
return sin(degree+90,range)
DAT
'assembly cog which updates the PWM cycle on APIN
'for audio PWM, fundamental freq which must be out of auditory range (period < 50?S)
org
entry mov dira, diraval 'set APIN to output
mov ctra, ctraval 'establish counter A mode and APIN
mov ctrb, ctrbval 'establish counter A mode and APIN
mov frqa, #1 'set counter to increment 1 each cycle
mov frqb, #1 'set counter to increment 1 each cycle
mov time, cnt 'record current time
add time, period 'establish next period
:loop rdlong value, par 'get an up to date pulse width
mov a, value
shl a, #16
shr a, #16
mov b, value
shr b, #16
waitcnt time, period 'wait until next period
neg phsa, a 'back up phsa so that it
neg phsb, b 'back up phsa so that it
jmp #:loop 'loop for next cycle
diraval long 11 'APIN=0
ctraval long 101 << 26 + 1 << 9 + 0 'NCO/PWM APIN=0
ctrbval long 101 << 26 + 3 << 9 + 2 'NCO/PWM APIN=0
period long 90 '888kHz (1.25?S period) (_clkfreq / period)
time res 1
value res 1
a res 1
b res 1
REV.1
CON
VAR
long parameter
word cs,sn
PUB go | x,y,z
repeat
repeat x from 0 to 359 step 15 '15 deg steps
cs:= cos(x,256) '+-8bit resolution
sn:= sin(x,256) '+-8bit resolution
parameter := cs << 16 + sn 'pack cosine and sine
'waitcnt(1000 + cnt) 'wait a little while before next update
c := angle & $800
z := angle & $1000
if c
angle := -angle
angle |= $E000>>1
angle <<= 1
s := word[angle]
if z
s := -s
DAT
org
mov a, value
shl a, #16 'unpack a
shr a, #16 'unpack a
mov b, value
shr b, #16 'unpack b
cmp a, #$1FF wc 'test for 16bit signed value
if_nc or a, mask 'sign extend
cmp b, #$1FF wc 'test for 16bit signed value
if_nc or b, mask 'sign extend
cmps a, #0 wc 'wave change
muxnc outa, #16 'status display
if_c movs ctra, #2 'out pin 2
if_c neg a, a 'flip sign
if_nc movs ctra, #0 'out pin 0
cmps b, #0 wc 'wave change
muxnc outa, #32 'status display
if_c movs ctrb, #3 'out pin 3
if_c neg b, b 'flip sign
if_nc movs ctrb, #1 'out pin 1
neg phsb, b 'back up phsb
diraval long 1111 'APIN=0
ctraval long 100 << 26 + 0 'NCO/PWM APIN=0
ctrbval long 100 << 26 + 1 'NCO/PWM APIN=0
period long 256 '800kHz (1.25?S period) (_clkfreq / period)
mask long $FFFF0000
time res 1
value res 1
a res 1
b res 1
