This thread is privately moderated by mlilasic, who may elect to delete unwanted replies.
Jan 31, 2019, 07:16 PM
FPV addict
mlilasic's Avatar
Mini-Review
Review of Xiaomi FIMI A3 5.8G FPV With 2-axis Gimbal 1080P Camera GPS RC QUAD
Review of Xiaomi FIMI A3 5.8G 1KM FPV With 2-axis Gimbal 1080P Camera GPS RC Drone Quadcopter RTF - 5.8G FPV
This is first time I see that high level quad like this with 1080P 2-axis Gimbal Camera uses analog 5.8GHz RF signal for video transmission. That means that along built-in monitor in remote you can use any 5.8GHz receiver/monitor or FPV goggles like this skyzone one I have and optionally combine ti with directional antennas like this to get better range.
This should be very interesting. Here is 1km range test (stuff use to record it is in video desc.)
Xiaomi FIMI A3 1km range DVR test - 5.8G FPV 2-axis Gimbal 1080P Cam GPS RC Drone Quad RTF (9 min 58 sec)
and sunny day HD footage:
Xiaomi FIMI A3 Sunny Day Flight - 5.8G FPV 2-axis Gimbal 1080P Cam GPS RC Drone Quad RTF (2 min 25 sec)
Maiden test flight:
Xiaomi FIMI A3 Maiden flight - 5.8G FPV 2-axis Gimbal 1080P Cam GPS RC Drone Quadcopter RTF 5.8G FPV (2 min 25 sec)
video file details:
Description:
FIMI A3 RC Quadcopter
Model: A3
Color: White
Dimension: 285*229*69mm
Diagonal Size: 323mm
Weight: 560g
Hover Accuracy: when GPS Positioning is active, Vertical: 0.5 m & Horizontal: 1.5 m
Max ascending speed: 6 m/s
Max descending speed: 5 m/s
Max cruising speed: 18 m/s
Max R/C distance: about 1km
Flying Limited Altitude: 500 m
Flight time: 25mins
(25mins flight time if fully charged by 4.35HV balance charger; about 21mins flight time if charged by original charger)
Wind resistance: ≤ 4
Satellite positioning systems: GPS+GLONASS
Operating frequency: 2.4-2.483GHz; 5.725-5.850 GHz (40CH)
Battery: 11.1V 2000 mAh 3S Lipo Battery
Package Weight: 1.68kg
Package Size: 344x292.5x107mm
Remote Controller
Screen resolution: 480*272
Screen size: 4.3inch
Frequency: 2.4-2.483GHz; 5.725-5.850 GHz (40CH)
Max R/C distance: About 1000m
Built-in Battery: 2950 mAh lipo battery with about 2.5h working time
Voltage: 3.7V
Charge port type: Micro USB
DVR: 720*480 video resolution
Gimbal
Controlled Rotation Scope: 0 ~ -90 Pitch angle
Stabilizaton: 2-aixs mechanical and 3-aixs electronical gimbal
HD 1080P Camera
Lens: FOV 80
Aperture: f2.0
Focal Distance: 3.54 mm
Equivalent Focal Distance: 27mm
Sensor: 1/3.2" CMOS
ISO Range: 100 - 3200 for video; 100 - 1600 for picture
Shutter Speed: 4 ~ 1/8000 s
Max Bitrate: 60Mbps
Max Photo Resolution: 8M 3264*2448
Video Resolution: 1920x1080 30 fps / 1920x1080 25 fps
File System: FAT32 / exFAT
Image Format: JPG
Video Format: MP4
DVR: 1920x1080 30 fps / 1920x1080 25 fps
Adapter
Rated Output: 14V 0.8A
Rated Input: 100-240V ~ 50/60Hz 0.3A
Rated Output Power :11.2W
Balance Charger
Rated Output: 11.1V 0.8A
Rated Input:14V 0.8A
Applicable Battery: 3S
Charging Limit Voltage: 12.75 V
Rated Voltage: 11.1 V
Rated Capacity: 2000 mAh / 22.2 Wh
Weight: about 162g
Propeller
Item Name: Quick-release propeller
Length: 7.5inch
Pitch: 3.6inch
Remarks from manufactured:
The flight time is tested with constant speed in breeze, the max flight time is 21mins for the single cell voltage at 4.2V;
25minis for the single cell voltage at 4.35V, and please use charger supported 4.35V.
4.35V HV Lipo Battery Charger Link: URUAV 2-3S HV 1.5A Lipo Battery Charger (Tested by FIMI)
Features:
1. HD 1080P camera powered by Ambarella ISP processor and Sony CMOS sensor, provides perfect HD picture and video.
2. The 2-aixs mechanical and 3-aixs electronical gimbal provides stable and smooth footage in any situation.
3. With lightweight design, the drone flies faster.
4. Wth quick-release propellers, fast and powerful propulsion with durable,well balanced design.
5. Flight time is up to 25mins with 11.1V 2000mAh lipo battery.
6. 1km range 5.8G real time transmission system.
7. With DIY port, you can explore your way to play with the drone, like driving a servo, lighting a led.
8. Remote Controller is built-in LCD screen, DVR, and User Interface.
9. Headless Mode,no need to adjust the position of aircraft before flying .
10. One key to return function makes it easily to find the way home.
Functions:
  • Up/down
  • Forward/backward
  • Turn left/right
  • Sideward flight
  • One key taking on/off
  • GPS mode
  • Headless mode
  • One key return
  • Follow me
  • Orbit
  • Fixed-wing mode
  • Dronie
  • DIY supported
  • Low battery protection
  • Automatic return losing signal
  • mode 1/ mode 2 switchable
In the box: (unboxing pics are in gallery)
1 x RC Quadcopter( with camera)
1 x Transmitter
1 x Gimbal
1 x 11.1V 2000mAh Lipo Battery
1 x USB Cable
6 x Propeller
1 x Charging Cable
1 x Balance Charger
1 x Manual(Download)
Pros:
Cons:
  • no setting for auto EV, pilot must track EV and adjust manually
  • slicing videos in 2m30s clips
  • charger gets the battery full but charger balancing performance is not so perfect, check post #4
Grab yours Xiaomi FIMI A3 HERE
FPV addict
mlilasic's Avatar
Lipo came in box at nice storage voltage:
Feb 01, 2019, 01:59 PM
FPV addict
mlilasic's Avatar
Now its charging in original charger so we will see final cell voltages:
Feb 01, 2019, 03:58 PM
FPV addict
mlilasic's Avatar
Charging results:
Battery is full, 12,64V, bat charger balancing performance is not so perfect.
Feb 02, 2019, 11:38 AM
FPV addict
mlilasic's Avatar
Video file details
Feb 02, 2019, 01:59 PM
FPV addict
mlilasic's Avatar
Follow me mode test:
works awesome
Xiaomi FIMI A3 follow me mode - 5.8G FPV 2-axis Gimbal 1080P Cam GPS RC Drone Quad RTF 5.8G FPV (2 min 25 sec)
Feb 02, 2019, 02:05 PM
FPV addict
mlilasic's Avatar
Orbit mode test:
works awesome
Xiaomi FIMI A3 Orbit mode - 5.8G FPV 2-axis Gimbal 1080P Cam GPS RC Drone Quadcopter RTF 5.8G FPV (2 min 25 sec)
Feb 02, 2019, 02:44 PM
I have just flown the FIMI A3 for the first time and noticed the the video clips are broker int o about 3 minutes segments. Is there a way to change this? Thanks in advance for any info.
Feb 02, 2019, 03:13 PM
FPV addict
mlilasic's Avatar
Mine are in 2m30s clips. Some drones do that, met a few.
Don't know how to turn that off, I afraid that the feature of the built-in DVR FW.
Feb 04, 2019, 01:37 PM
FPV addict
mlilasic's Avatar
Night performance test
ISO: AUTO
Shutter: AUTO
EV 0
Xiaomi FIMI A3 Night performance test - 5.8G FPV 2-axis Gimbal 1080P Cam GPS RC Drone Quad RTF (2 min 25 sec)
Feb 09, 2019, 12:32 PM
FPV addict
mlilasic's Avatar
1km range test DVR:
Other equipment used to record this flight:
Skyzone FPV goggles - http://bit.ly/2M7Rgnv
with ImmersionRC SpiroNet 5.8GHz RHCP Antenna - https://goo.gl/aFuLfr
URUAV UXII 5.8GHz 220Mhz 8.4dBi Gain 76 Degree RHCP FPV Patch Antenna: http://bit.ly/UruavUxii
HMDVR Mini DVR - https://goo.gl/xOtjm0
New Product Xiaomi FIMI A3 5.8G 1KM FPV With 2-axis Gimbal 1080P Camera 25mins Flight GPS Drone Merch Banggood.com 15 Today 08:04 PM
New Product Xiaomi FIMI A3 5.8G FPV 2-axis Gimbal 1080P Camera GPS Quadcopter - Free Reviewing BGKevin Multirotor Drone Talk 68 May 25, 2019 12:36 PM
New Product Xiaomi FIMI X8 SE 5KM FPV With 3-axis Gimbal 4K Camera GPS 33mins Flight Time RC Dron alex_nikiforov Banggood.com 1 Mar 16, 2019 03:20 PM
Discussion C-Fly Obtain GPS 720P 1.2KM WIFI FPV With 3-Axis Gimbal 1080P HD Camera RC Drone Quad scousethief Banggood.com 0 May 28, 2018 07:57 AM
Discussion UPair UP Air 5.8G FPV 1080P 12.0MP SONY HD Camera With 2-Axis Gimbal RC Quadcopter etcyberdude Multirotor Drone Talk 2 Nov 08, 2015 07:36 AM
