Jan 30, 2019, 06:44 PM
New Product
E-flite F-15 Eagle 64mm EDF BNF Basic/PNP
BNF Basic version with AS3X and optional-use SAFE Select:
https://www.horizonhobby.com/f-15-ea...safe-p-efl9750
PNP version (no receiver or AS3X/SAFE Select):
https://www.horizonhobby.com/f-15-ea...df-pnp-efl9775
When it comes to air superiority, none have yet succeeded against the one and only F-15 Eagle in air-to-air combat. So advanced and formidable, the F-15 is expected to log a 60-year long service life. The E-flite® F-15 Eagle 64mm EDF jet is a potent replica of the McDonnell Douglas design that makes it possible to enjoy the thrill of flying an air superiority fighter of your own. It's also the easiest F-15 model to fly when equipped with AS3X® and SAFE® Select technologies (BNF® Basic version only).
Key Features
- The easiest to fly high-performance F-15 Eagle EDF (Electric Ducted Fan) jet model yet
- Scale replica of the world-renowned air superiority fighter flown by the U.S. Air Force
- 11-blade 64mm fan delivers great vertical performance and top speed plus turbine-like sound
- Factory-installed high-power 4S-compatible brushless motor, 40-amp ESC and 5 servos
- Spektrum™ 6-channel 2.4GHz receiver with industry-leading DSMX® technology
- Unmatched stability and precision of AS3X® technology for smoother flight performance
- Easy to fly with optional-use SAFE® Select flight envelope protection
- Optional-use fixed landing gear with steerable nose wheel
- Bolt-on wings with removable tanks and missiles
- Magnetically-secured nose cone and top hatch
- Durable yet lightweight molded EPO airframe
Needed to Complete
- Full-range 5+ channel DSMX®/DSM2® transmitter
- 4S 14.8V 2200mAh 30+C LiPo with EC3™ or IC3™ Connector (SPMX22004S30 recommended)
- Compatible LiPo charger
Overview
The E-flite® F-15 Eagle 64mm EDF jet is a replica of the world-renowned air superiority fighter flown by the U.S. Air Force. It's equipped with a 4S-compatible brushless motor and a 40-amp ESC that are matched to an 11-blade fan to deliver fantastic speed, thrust and a turbine-like sound. The factory-installed power system and servos help make it quick and easy to assemble the lightweight yet durable EPO airframe with bolt-on wings so you can be flying in less time than it takes to charge a battery. Optional-use fixed landing gear with a steerable nose wheel is included so you can taxi, take off and land on runways, or you can leave the landing gear off for improved performance plus easy hand launches and landings on grass. You can also fly with or without the wing-mounted drop tanks and missiles depending on the look and handling you prefer. And it all adds up to deliver one of the easiest to enjoy and easiest to fly Eagle models ever!
Exclusive Technologies
This is the first high-performance F-15 model equipped with exclusive Spektrum® AS3X® and SAFE® Select technologies. AS3X works behind the scenes to smooth out the effects of wind and turbulence to deliver a locked-in feel that makes it seem like you're flying a much larger jet. Optional-use SAFE Select offers pitch and bank angle limits along with automatic self-leveling that can be turned on and off at the flip of a switch making this the easiest to fly Eagle yet! And if you don't want to enable the SAFE Select features, simply bind the receiver normally and only AS3X will be active.
High-Power EDF
The 11-blade 64mm fan, high-RPM brushless motor and 40-amp ESC combine with your 4S 2200mAh LiPo battery to deliver great vertical performance and a fantastic speed range with virtually instantaneous throttle response. But what makes the experience truly rewarding is the fantastic sound produced by the power system- it's almost like a real turbine.
Gear Options
You can install the included fixed landing gear with steerable nose wheel to taxi, take off and land on smooth surfaces. Or you can leave the landing gear off for more speed and vertical performance plus easy hand launches and landings on grass.
Unique Trim Scheme
The factory-applied paint and decal finish replicates the aggressor squadron “splinter” trim scheme found on F-15s used to act as an opposing force while providing a realistic simulation of air combat.
Durable Design
Construction with molded EPO material makes it possible to replicate complex detail and shapes in a lightweight yet durable form. The result is an outstanding scale appearance that's easy to maintain and delivers the best possible flight experience.
Compact Convenience
Although the F-15 Eagle 64mm EDF is compact enough to transport in just about any vehicle in one piece, it features bolt-on wings and a magnetically-secure nose cone that are easy to remove/install for even more convenient transport and storage.
Jan 30, 2019, 06:45 PM
E-flite® F-15 Eagle 64mm EDF PNP & BNF Basic Jet (2 min 29 sec)
Jan 30, 2019, 07:15 PM
Bizjets's Avatar
Nice! I love that you guys are coming out with BNF EDFs.
Jan 30, 2019, 07:24 PM
Thank you We’re very excited about this one because we think a lot of people will be able to afford and enjoy it (we’re also excited about the next one, which is an all-new, ground up design...and the next one after that, then the next one... )
Jan 30, 2019, 09:07 PM
Wanted: More Time to Fly
Topdogzrc's Avatar
F/A-18? Given the Viper and F-16, a F/A-18 as a BNF with AS3X would be awesome, and I know a few who'd buy it as they're Hornet fans
Jan 30, 2019, 09:37 PM
An F/A-18 could/would be nice...
Any other guesses??
Jan 30, 2019, 09:56 PM
Topdogzrc's Avatar
Any other guesses??
F-15 would be cool too, though I don't think y'all would do an F-16 aggressor but I may be way wrong (my bias is T-bird F-16s no matter what ). If it is the F/A-18 though I know a few of my buddies will get them no doubt, one needing an 'upgrade' from his old Starmax F/A-18
Jan 30, 2019, 10:05 PM
It technically is a “twin”...
Jan 30, 2019, 11:01 PM
Based on the hints, I'm gonna say a 64mm EDF F-15.
Really looking forward to Horizon's EDF releases this year. I still have my E-Flite 400DF (64mm EDF) F-16 Thunderbird with the 4800kv "high performance" motor...I put about $350 into it back in the day...boy times have changed for the better.
Great to see Horizon getting back into the EDF market!
Sean
Jan 30, 2019, 11:33 PM
DJROTC's Avatar
I think it's a 70mm F-15
Jan 30, 2019, 11:48 PM
Any other guesses??
Hmm im gonna say f15 but would love you guys to do the f18 70 in blue angel and as3x please But yes i am getting one of these 15s too. If its a 70 and new model not the older 64mm version with new paint . Also SUPER excited about your orginal ones coming!!https://www.instagram.com/p/BselMMlB...=1l4ogtllc4bal
Jan 31, 2019, 12:15 AM
You guys are good
And since it’s already Thursday for some...
The product pages aren’t live just yet, but they should be in the next few hours!
BTW, we know some may have seen a variation of this before, but with the addition of AS3X/SAFE Select in the BNF Basic version it flies even better and will be even easier for more people to fly/enjoy...plus we think it looks better too (granted, looks are subjective...)!
Also, as noted before, the next one is an all-new, ground up design, but in the meantime this will be a fantastic addition to our growing line of EDFs
Jan 31, 2019, 02:20 AM
You guys are good
https://youtu.be/rweph1Puul0
I must say looks great as a flyer. Of course i appreciate that you guys also support the skillset and passion /dedication of the hobby and hire smooth pilots like Ali! Im really excited to see your guys upcomming original edf too!
Jan 31, 2019, 02:37 AM
Looks totally awesome...
I guess they did the same as with the Force RC F-18 Blue Angels plane - took an older FMS plane and upgraded it to 4S?... Whatever the case, love the paint scheme. Looks floatier than the F-18. Very nice...
Jan 31, 2019, 08:08 AM
Thank you everyone
The product pages are live now and you can see all the info for both available versions here:
https://www.horizonhobby.com/SearchD...n=01312019_AIR
Also, an EXTREMELY limited quantity will be coming in the first shipment due to the US next week, so if you want to get one ASAP be sure to pre-order NOW! Otherwise you’ll have to wait until the next shipments arrive in March/April
Article The NEW E-flite Timber X 1.2m BNF Basic/PNP - Get STOL3D! Jason M Electric Plane Talk 2677 Today 10:13 AM
New Product E-Flite Timber 1.5m BNF Basic/PNP Mattfly Electric Plane Talk 17120 Today 08:16 AM
Alert E-flite Spitfire MKXIV 1.2m BNF Basic Thecheesemiester Electric Warbirds 2362 Oct 07, 2019 12:38 PM
New Product E-Flite Clipped Wing Cub 1.2m BNF Basic and PNP Micubano Parkflyers 16 Feb 08, 2018 01:04 PM
