This thread is privately moderated by mlilasic, who may elect to delete unwanted replies.
Jan 25, 2019, 03:55 PM
FPV addict
mlilasic's Avatar
Mini-Review
Review (ip) of iFlight XL7 V3 True X 7 inch Long Range Freestyle Frame Kit Arm 4mm
Review (ip) of iFlight XL7 V3 True X 7 inch Long Range Freestyle Frame Kit Arm 4mm for FPV Racing Drone
My 7" frame for my LR quad just came
Specification:
Brand name: iFlight
Item name: XL7 V3 Frame Kit
Type: 7" Freestyle frame
Frame wheelbase: 295mm
Dimensions :208mm x 208mm(body dimension)
Motor c-clip hole: 8mm
Standoff Height: 30mm
4mm arms,1.5mm vertical side plates
2mm top,upper&bottom plate
Mounting Holes: 30.5*30.5mm
Frame weight:
Features:
- Chamfered Edge High quality Pure 3K carbon plate
- Adjustable camera placement
- Top mounted battery for optimal CG
- True X frame design
- Replaceable 4mm arms and plates
- High quality 3K full carbon
- Grade 12.9 Black Nickel Plating high quality screw hardware
- Compact design
In the box:
Grab yours iFlight XL7 V3 LR Frame HERE
Jan 25, 2019, 03:56 PM
FPV addict
mlilasic's Avatar
Other parts for the build:
Eachine TX806 leaf 5.8Ghz 72Ch 25mW/200mW/400mW/800mW/1000mW AV FPV Transmitter Smart Audio w MMCX & MIC
RunCam Split 2S
BN-220 GPS GLONASS GPS
45$ FrSky R9M 900MHz Long Range Transmitter Module With R9 MM combo
Racerstar BR2207 1600KV motors
MAMBA F405 Betaflight Flight Controller & F40 40A 2-6S DSHOT600 FPV Racing Brushless ESC
Zip Ties - https://goo.gl/SvvZTm
Threadlocker - https://goo.gl/fVRTg9
capacitor - http://bit.ly/2yPKgHe
battery strap - https://goo.gl/YQdV7a
Skyzone FPV googles - https://goo.gl/zXK8Zg
with ImmersionRC SpiroNet Antenna
and URUAV UXII 5.8GHz 220Mhz 8.4dBi Gain 76 Degree RHCP FPV Patch Antenna
HMDVR Mini DVR - https://goo.gl/xOtjm0
Transmitter:
Taranis Q X7 transmitter - http://goo.gl/iMrQu6 - My Q X7 Review
or
Taranis X9D Plus Transmitter SPECIAL EDITION - https://goo.gl/MxLKKF - My X9D Plus Review
or
Jumper T12 Open TX - http://bit.ly/2NKechw - My T12 Review
Charger:
ISDT Q6 Plus 300W 14A MINI Pocket Battery Balance Charger - https://goo.gl/ZhxnYQ
or
HOBBYMATE D6 DUO PRO - ACDC BATTERY CHARGER - https://goo.gl/BgEJz4
Battery:
Giant Power DINOGY MEGA GRAPHENE 2.0 1550mAh 14.8V 75C Lipo Battery - https://goo.gl/nTjGCi
or Giant Power Dinogy 1500mAh 14.8V 4S 65C LiPo Battery - https://goo.gl/AJGkYi
or 6S CNHL G+PLUS 22.2V 1500mAh 6S 100C Lipo
In my DIY builds I use this inexpensive gear:
32$ EPAI Metal Base Universal 4 Flexible Arms Soldering Station PCB Fixture Helping Hands
ANENG AN8002 Digital True RMS Multimeter
31$ CXG 936D EU Plug 220V 2in1 LCD Adjustable Temperature Digital Electric Solder Iron Soldering Station
or
34$ CXG US Plug 110V High Precision 936d LCD Adjustable Temperature Digital Electric Soldering Station
14$ DANIU 220V 300W DIY Electric Heat Shrink Gun Power Tool Hot Air Temperature Gun with Supporting Seat
5$ DANIU Electrical Cutting Plier Wire Cable Cutter Side Snips Flush Pliers Tool
3M Double Sided Adhesive Tape Super Sticky Acrylic Foam Sticker to secure VTX and receiver
XIAOMI Wowstick 1P+ 19 In 1 Electric Screw Driver Cordless Power Screwdriver
My Review of EPAI Metal Base 4 Flexible Arms Soldering PCB Fixture Helping Hands
Feb 02, 2019, 03:31 AM
What is the flight time and range?
Aug 05, 2019, 11:02 AM
What are your thoughts about the frame?
Discussion SkyStars G730L 7 inch FPV Kit/PNP - Budget Freestyle/Long-range quad! BobFromMars Mini Multirotor Drones 178 Nov 25, 2019 09:33 PM
