This thread is privately moderated by mlilasic, who may elect to delete unwanted replies.
Jan 23, 2019, 05:17 PM
FPV addict
mlilasic's Avatar
Mini-Review
Review of Eachine TX806 leaf - VTX 5.8Ghz 72Ch 25mW/200mW/400mW/800mW/1000mW
Review of Eachine TX806 leaf 5.8Ghz 72Ch 25mW/200mW/400mW/800mW/1000mW AV FPV Transmitter Smart Audio MMCX MIC
My VTX unit for my LR quad (more details on the quad HERE) just came:
1km test flight:
Eachine TX806 leaf + URUAV UXII 5.8GHz - 1km range test - (7 min 37 sec)
Features
  • Support smart audio
  • 25mW/200mW/400mW/800mW/1000mW power switchable
  • One key searching and power setup
  • OSD configuration using smart audio
  • Wide input voltage with 5V for camera
  • Solid MMCX antenna connector and rp-sma pigtail cable
  • Digital display
  • 72 channels with MIC
Description
Operation
Channel Select - Select channels by simple short presses, by ordinal display for channel(CH:1 2 3 4 5 6 7 8)
Band Select - Press button for 2s, LED will flash, then short presses to select band (Band: ABEFRUOLH)
Power Select - Press button for 4s, LED will flash, then select power by simple short press
"1" stands for "25mW"
"2" stands for "200mW"
"3" stands for "400mW"
"4" stands for "800mW"
"5" stands for "1000mW"
The LED will display "channel" "band" "power" successively after setting.
Note: LED flash 2 times quickly while displaying power ,eg, "1" flashes 2 times means "25mW"
Pit mode(0.01mW) :
While the VTX is pit mode, the LED shows "P" and flash.
While in pit mode, you can switch channels and set power levels, but none of these changes will take effect until you quit pit mode. By default, pit mode will send a very weak signal
In the box: (unboxing pisc are in gallery)
1 x TX806 5.8Ghz 72 Channel 25mW/200mW/400mW/800mW/1000mW switchable Transmitter
1 x MMCX to RP-SMA pigtail cable
1 x MMCX linear antenna
1 x JST-SH 1.0mm 6P cable
1 x User manual
Grab yours Eachine TX806 HERE
Jan 23, 2019, 05:18 PM
FPV addict
mlilasic's Avatar
res
New Product Eachine TX806 leaf 5.8Ghz 72Ch FPV Transmitter Smart Audio MMCX MIC -- Free Reviewing BGKevin FPV Equipment 17 May 12, 2019 01:00 AM
Discussion PandaRC VT5804 V3 25mW/200mW/400mW/800mW/1000mW Switchable Video Transmitter myrcmodel FPV Equipment 0 Jan 02, 2019 01:21 AM
New Product Eachine DVR03 DVR AIO 5.8G 72CH 0/25mW/50mW/200mW Switchable VTX 520TVL 1/4 Cmos FPV kremerFPV FPV Equipment 21 Jul 22, 2017 03:19 AM
