Graupner - NEW SERIAL 2.4GHZ DIVERSITY HOTT RECEIVERS
The new Graupner GR-12L diversity RX is coming in February. Learn more here!
Splash !!From Graupner Our new serial GR-12L diversity receivers provide the much-needed flexibility for those that use flight controllers in need of a reliable RF link combined with real-time telemetry information. Communication between the serial receiver and flight controller can be set for SUMD, SBUS or SP2048 using a single wire which reduces installation complexity and wire clutter. There are two models available where each provides installation flexibility depending on user needs. The PCB version provides installation options to existing frames such as multi-rotors and provides connections to additional servo or switching channels for LED or switching transistors. [img]https://www.rcgroups.com/forums/showatt.php?attachmentid=11599145[/img] Real-time telemetry for RSSI, voltage and temperature are provided and RSSI information is provided as part of the serial communication stream. The GR-12L serial diversity receiver is designed to interface with third party flight controllers like Betaflight, Raceflight, Potenza, Bavarian Demon, Spirit, V-Stabi, Microbeast, Ikon, Neuron, 3Digi or any SUMD/SBUS/SP2048 compatible flight controller. Availability: Early February 2019 !Learn More Head over to the Graupner site for more information!! !! Product Links: https://www.graupnerusa.com/GR-12L-1...ity-S1046.html https://www.graupnerusa.com/GR-12L-1...ity-S1045.html
Jan 23, 2019, 08:11 PM
100% electric since 1990
twest's Avatar
Just to clarify the picture above, the receiver is the tiny gray shrink wrapped thing, not the giant red item (gyro or flight controller I think)
Jan 24, 2019, 12:27 PM
Graupner USA's Avatar
Correct.
The device next to it is one of the many products the receiver will work with and illustrates how compact installation can be when used with those receivers.
Review Graupner/SJ mz-24 2.4GHz HoTT 12 Channel System pda4you Radios 2663 Yesterday 12:09 AM
News Graupner mz-12 PRO 12 Channel 2.4GHz HoTT Transmitter Matt Gunn Radios 97 Sep 20, 2018 07:12 AM
New Product Graupner's new HOTT 2.4GHz system. Julez Radios 3831 Aug 11, 2018 06:13 PM
Discussion GR-12SC+ 6 Channel 2.4GHz HoTT Receiver phil alvirez Radios 0 Nov 29, 2015 07:29 PM
Discussion Graupner's HOTT 2.4GHz system. Dyno Don Radios 5 Jun 23, 2015 10:34 AM
