Jan 22, 2019, 08:38 AM
Quad Erat Demonstrandum
scousethief's Avatar
New Product
Frsky Neuron 40A 32Bit 3-6S Input Brushless ESC Built-in Telemetry for FPV RC Airplan
https://www.banggood.com/Frsky-Neuron-40A-32Bit-3-6S-Input-Brushless-ESC-Built-in-Telemetry-for-FPV-RC-Airplane-p-1416237.html
Dont know why this hasnt been posted, its a "Plane" Esc that can feedback via a Frsky receiver to you transmitter, it is massively overpriced but still , lots of people buy Frsky because its Frsky.
Frsky Neuron 40A 32Bit 3-6S Input Brushless ESC Built-in Telemetry for FPV RC Airplane
Overview:
The FrSky Neuron Series ESC is a professional grade control unit, integrated with built-in telemetry like high-precision current sensor, voltage sensor, motor RPM, power consumption and ESC temperature sensor. Features optional DShot signaling and an adjustable SBEC voltage, that can Be changed via LUA script (Sbec_v1.0.lua). The Neuron ESC is encased in a CNC aluminum protective shell which also aids in heat dissipation. As with most FrSky products, the Neuron series is completely S.Port compatible, allowing you to Use our full line of S.Port Telemetry sensors.
Description:
Brand name: FrSky
Item name: Neuron 40A ESC
Dimension: 59*33*17mm (LWH)
Weight: 58g
LiPo Cells: 3~6S
Adjustable SBEC Voltage: 5~8.4V (Voltage Step: 0.1V)
Current: 40A
Peak Current: 60A
Features:
* Smart Port enabled and telemetry data transmission supported
* Telemetry data for ESC: Voltage, Current, RPM, Power Consumption, Temperature.
* Telemetry data for SBEC: Output Voltage, Current.
* High performance 32-bit micro-processor
* High-precision current sensor ACS781KLRTR-150U-T (Resolution 125mA, Precision 2%) and ACS711KEXLT (Resolution 50mA, Precision 2%)
* Over-temperature and over-current protection
* Optional Dshot signaling (Dshot 150/300/600)
* SBEC supports [email protected]~8.4V (Adjustable through LUA )
Package Included:
1x FrSky Neuron 40A ESC
Mar 16, 2019, 10:45 PM
If I build it, it will fly
Show me another SINGLE unit with the same specs at a lower price.
~psguardian
Discussion Flycolor X-cross 40A 3-6S Blheli_32 32Bit 5V/1.5A BEC 4 IN 1 FPV Racing Brushless ESC BGjim Banggood.com 1 Oct 23, 2018 08:36 AM
New Product Flycolor X-cross 40A 3-6S Blheli_32 32Bit 5V/1.5A BEC 4 IN 1 Brushless ESC Merch Banggood.com 0 Oct 17, 2018 02:54 PM
New Product T-motor F55A Pro 4 IN 1 55A 3-6S Blheli_32 32Bit Brushless ESC DSHOT600 for RC Drone scousethief Banggood.com 1 Oct 10, 2018 07:15 PM
New Product Holybro Tekko32 35A 3-6S Blheli 32 4 In 1 Brushless ESC support Telemetry for FPV Rac jaganfpv Product Announcements 0 Mar 13, 2018 09:15 PM
Discussion 20x20mm HGLRC 40A BLheli_32 3-5S 32Bit 4 In 1 Brushless ESC DShot1200 for RC Drone FP scousethief Banggood.com 2 Dec 23, 2017 06:58 AM
